Rear brake pad pins seized.
2007 cls63 AMG
Tried penetrating oil and a drift punch with big hammer. There is no give! Is drilling my only option? I can drill the front while it is still on the car but to drill the back I need to take caliper off! What can I plug the brake line with as I do this ?
Any other tips? I don't have a press so I will be hand drilling.
2007 cls63 AMG
What a poor design!! so you drilled it all the way through the front?. the reason y i ask is because the pin is tapered. So if i put the drill on the outside i only have access to the small end of the pin. once i drill that completely, the big end is on the back side and if i try to drill straight from one of the pin to the other, i will enlarge the small hole and the new pin will not seat in. any tips ?
2007 C280 4matic Avantgarde
I found out that wire from dry cleanning hanger has right diameter for that hole, maybe a bit soft but few tries could do the trick. I did it on first try, probably because wasn't stuck as bad. If you find some more solid wire even better.
Here is how was done.
Put wire inside a hole and cut it 5 mm to stick out.
Remove piece and sand it flat on both sides so after that sticks out 3-4 mm.
Put it back and, find hammer with both flat end (or something similar), hold it on wire end and hit very hard that hammer (or SS) with another one (hammer)
Good Luck!
2003 C230K Coupe Orion Blue
Can someone take a photo? Which pin are we talking about? The only pin I know on the W203 are in the rear, and they can be pounded out with a screwdriver?
2019 C300 Wagon; '75 Triumph TR6; previous: 2004 C230 6spd sold after 17 years of driving
with the sports package the sedan has fixed calipers either 4 pots (2004 and earlier and C32/55) or two piston (2005 to 2007) made by Brembo on the front which also has pins securing the pads. The coupe and non sports versions have a single piston sliding caliper made by Lucas
2007 cls63 AMG
yes, usually that pin can be pounded out with a screw driver. However when it seizes because of salt on the road exposure over time, it is a pain to take out.
I doubt the coat hanger trick will work because i have a drift punch that fits in well and pounded on it with a big hammer and bent the punch. I am afraid of heating it and ruining the seals on the caliper!
I had to put everything back temporarily so that i can pick up spare pins on monday and then try drilling this stupid pin out.
The pin is so exposed, wherever they put salt on the road, it will seize right up. Anybody ever tried heating it or will i ruin the caliper ?
2005 c230 kompressor 2003 s500 94 wrangler
just drill out the small end which faces u out....this is the only thing u can do...or u can buy another caliper for 200
u only have to drill a little bit of the pin...until u can smash it out with the drive pin
2007 cls63 AMG
so you are saying to drill out the small end, cut the inner end of the bigger pin, put a bigger punch on it and go at it ?
Former Vendor of MBWorld
Brembo caliper pad pin punch
We have just release this handy tool to make your brake pad replacement easier:
http://forums.racingbrake.com/showthread.php?t=1390
