Brake Grinding Noise...Need Help!
Old May 10, 2012 | 03:00 AM
livelife's Avatar
06 c230 sport
My 06 c230 has brake grinding noise from the front. I replaced the rotors and the pads recently and it's still there. I did research on this forum and I still can't find any answer.
I'm new to the Benz world going from a e46 m3 to a Benz.
If anyone might know what I should do, please help me out.
Oh by the way, my brake bearings are fine.
Thank you in advance.
Old May 10, 2012 | 08:38 AM
mtrevelino's Avatar
2006 E320 CDI
Please provide additional information such as:
--What brand rotors did you install.
--What brand pads did you install.
If you did not install MB oem parts, it could be either one or a combination of the above. If you did use oem parts, I do not know why you are getting the grinding noise.
Good luck,
Mike T.
Old May 10, 2012 | 09:49 AM
livelife's Avatar
06 c230 sport
Rotors are OEM but pads arent. I did my homework before purchasing the pads here on the forum and got great reviews about it
Old May 10, 2012 | 11:42 AM
04mbc230's Avatar
2006 C230 Sedan
Have you use a small packet of paste for the pad and shims which they call it brake pad silencer. I believe this stuff help holds the pad in place when its not squeezed for braking. When not braking sometimes the pad is loose and scrapes the rotors which makes the noise you hear.
Now, if only the noise you hear is a metalic scraping noise. Of course if its something else, it could be the boot it something more serious.
Old May 10, 2012 | 01:55 PM
sammydragon3's Avatar
2005 c230 kompressor 2003 s500 94 wrangler
i had the same prob as u when i swtiched out the rotor (balo) and pads (ones from autozone) but still a low grinding noise on turns.that entire time my bearing was out
u can have a bad wheel bearing...this is what im experiencing now...still havent got it fixed
take off the wheel at least and try yanking on it
but if u have exp take off the wheel, caliper, rotor, and hub cover and look at the grease and grab the wheel hub and yank it everywhich way
Old May 10, 2012 | 05:30 PM
livelife's Avatar
06 c230 sport
From what I know, the wheel bearing is good
Old May 11, 2012 | 04:36 PM
mine went out at 50k miles...i never knew it tho
Old May 12, 2012 | 03:45 AM
livelife's Avatar
06 c230 sport
I just don't know what to do to fix the noise. I hate driving the car this way. Everyone stops and looks like what is this train doing here. It's embarrassing
Old May 12, 2012 | 05:33 AM
livelife's Avatar
06 c230 sport
My car has 65600 miles
Old Feb 21, 2020 | 07:19 PM
lkthaman_9's Avatar
2001 c320 and 2017 GLE350
Guys i am having the same grinding noise with my C320 and the parts are OEM but still the grinding noise is there. Pls help to guide me what to do. Thanks in Advance
