5w30 vs. 0w40 Mobil One
Hey Guys,
I know this has been debated endlessly, but everything I read has answers that contradict, so I thought I'd ask the experts (you guys). I know Mobile 1 ESP 0w40 is the oil of choice for Long Interval changes, but I really don't feel comfortable with the whole 12,000 mile change. So, my question is if I use a 5000 mile interval, can I use 5w30 instead? Is 0w40 preferred as it's a long interval oil ONLY, or is there a larger difference (sulfur ect..)
Thanks!
Thanks!
There is no contradiction here. You may use any 229.5 approved oil. 229.51 is the approval for diesel cars and is not for gasoline ones.
Also, the 1yr/13000 mile change interval is fine. You will waste money and resources changing it more often. My car has had 10 lifetime oil changes and will break 140,000 miles soon. At last oil analysis somewhere in the 125k mile range, the engine was in top shape and they suggested that I try 15,000 mile intervals.
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
I use 0w40 and change it every 5-6k miles for peace of mine cuz it looks pretty dirty every time i do...the dealer up here though puts in 5w30 i noticed when i was in there the other day...another reason why I don't go tot he dealer for anything but parts and major things I don't have the time to fix
2014 E350, 2006 C350 Sport(made it to 280k, loved it!), 1990 300E
The only reason I would say always go with the 0w-40 is that you can find it in almost any town in the USA. The only other 299.5 approved oil I have actually seen in the USA is the Pennzoil 5w40 European Formula but I was only able to get that from my dealer (for a very nice price btw) But when my car was down a Quart I could not find it anywhere and finally just went to the dealer to get a few quarts. I have also heard that the Mobile One is a better oil from people on here but I am not an oil expert and won't get into that but I figure if Mercedes approves it and they come from the same base stock I will roll the dice on it. That said next oil change I will make sure I use Mobile One just for the convenience factor. Heck the dealer may have it dirt cheap too. I am sure Glyn will comment on this I can't remember what his opinion was on which oils are better.
Link about the Pennzoil
https://mbworld.org/forums/c-class-w...ip-me-off.html
Super Moderator
You can use any 229.5 approved oil. Just be careful. Some of the Mobil 1 5W-30's have approval & some don't.
What oil looks like has no bearing on anything, just as an FYI. You can't judge the life of the oil that way. I mean unless something is very obviously wrong, that is. But just because oil looks "dirty" means nothing.
Super Moderator
If oil looks dirty it shows that the detergent pack is doing it's job. Modern oils should blacken very quickly.
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
Glyn,
Funny but I was just thinking to ask you that the other day.
What causes oil to turn black?
I'm still 5-6K away from the next change and it's turned black
as night, 0w-40 M1. So, I guess it's ok.
2019 C300 Wagon; '75 Triumph TR6; previous: 2004 C230 6spd sold after 17 years of driving
from the Mobil 1 site:
: If my motor oil turns black, does that mean it's time to change the oil?
Chinn: This is a myth we hear a lot. But the truth is the color of an oil has absolutely no bearing on its lubrication ability. Nor does it automatically signal that you need an immediate oil change.
In fact, many oils will turn black in the first few hours of operation due to contaminants generated by the combustion process and soot particles. The engine combustion process produces soot and other byproducts that then can spread throughout the oil, resulting in the oil having a dark, almost black color.
For cars that are in good condition, the resulting black color typically means that the oil is doing its job, cleaning out soot and other byproducts of engine combustion.
In addition, some additives used in modern oils can produce a dark color over time and this is normal
It is best to change your oil based on time in months or miles. To find the optimum oil drain interval, refer to your owners’ manual to get the vehicle manufacturers’ recommended oil drain interval.
For first time Mobil1 users, it may be possible that the black color of the oil indicates that the strong additive package formulated into Mobil 1 is actively removing deposits from the engine.
Former Vendor of MBWorld
SpeedRiven SL600, ML320CDI
If you were to use non-MB oil, I would recommend 5w-40. BTW, if you are not planning on driving 12K miles, 229.3 approved oils might be better choice...
We do use Liqui Moly 5w-40 and 0w-40 extensively, but always stock MB 0w-40. Mannheim 5w-40 is another choice for many MB owners and I always like to have couple cases of that in stock as well.
Igor.
Igor.
Dealers are cutting corners.
I really don't understand what all the constant debate is about personally. The 229.5 spec oil is easy to find and cheap. Yet people constantly are wanting to swap it up for no reason. I just don't get it.
I could not disagree - 229.5 all-the-way. Liqui Moly we are using is 229.5 and it is 20$ cheaper than MB OEM (per oil change). I never had any complains about Liqui Moly in my 10 years in MB business.
Igor.
Which Liqui Moly is 229.5 approved I could not find any that were not 229.3 or 229.51. I will say I could have just missed it.
https://mbworld.org/forums/c-class-w...nts-usa-3.html
229.5
LIQUI MOLY 5W-40 LEICHTLAUF HIGH TECH x Liqui Moly GmbH, Ulm/Deutschland
229.51
Liqui Moly 5W-30 TOP TEC 4200 x Liqui Moly GmbH, Ulm/Deutschland
Liqui Moly Longtime High Tech x Liqui Moly GmbH, Ulm/Deutschland
Liqui Moly Pro-Engine M 500 x Liqui Moly GmbH, Ulm/Deutschland
Liqui Moly Top Tec 4600 x Liqui Moly GmbH, Ulm/Deutschland
One of those appear to be 229.51 oils from my research you may want to check on that
229.5
229.51
229.5
229.51
Sorry, I took couple days off to make long weekend an extra long
Igor.
