Leaking camshaft solenoid magnets DTB/TSB - M271
Old Aug 18, 2012 | 11:55 AM
Glyn M Ruck's Avatar
Super Moderator
Member selwyng is going to the Motor Industry Ombudsman in SA re the leaking camshaft solenoid magnets issue. Does anyone have a copy of the US bulletin for him or US correspondence in this regard. We have been through all the threads.
Campaign # 2009100001
Cam Solenoid recall
271-051-01-77 Magnet
271-051-00-32 Closing Cover
271-050-27-33 electrical wire
Covers: Models 170/203, Model Years 2001 - 2004 / 2002 - 2004
Replace the Camshaft Adjustment Solenoid(s) and Install Adapter Harnesses (pigtails)
Old Aug 19, 2012 | 09:52 AM
Hatchman's Avatar
'05 C230 Kompressor Sedan
Afraid I can't help, but bump for you. I sent an email to MBUSA two weeks ago and still have no reply. Luckily, my local stealership said my '05 was listed on the campaign, so getting the work done in two weeks.
Edit: finally got a reply via email from Maria at MBUSA saying my 2005 as already on the campaign, and to go to my local dealer to get it completed.
Old Aug 19, 2012 | 11:00 AM
jetta02awp's Avatar
2002 C230 Coupe Kompressor 6mt
I stopped at my local MB dealer the other day to see if there was any open recalls on my 02 Coupe and they told me that there was on the camshaft solenoid. They are taking care of it on Wednesday
Old Aug 21, 2012 | 08:24 AM
BF_JC230's Avatar
2005 w203 C230
REALLY?!?! The 2005s are on this list now...please confirm. I added the pig tails and check every oil change - but this is news to me! Thanks!
Old Aug 21, 2012 | 10:07 AM
Hatchman's Avatar
All I can say is my 2005 was already on the list, confirmed at my stealership and the email reply from MBUSA. They wouldn't say if EVERY 2005 was on the list, but mine was. I have seen many other posts from 2005 owners that their 2005 was also already on the list and they got the work done, though some only got the connectors/extensions wires and not anything else.
So everything points that the 2005's have been added, but the amount of parts you get at the dealership may vary. Even if it is not on the list, a quick email to MBUSA should get your car added/or confirm that it is already on there.
I am hoping that I get new cam sensors, o-rings, and isolaters, since both my cam sensors are leaking. I'm going to ask them to check all the other connections (ECU, O2 sensers, etc) and see if the oil has migrated through the rest of the harness. If it has, maybe they will replace all affected parts under the campaign.
Will report back 31Aug after I have the work done.
Old Aug 21, 2012 | 10:15 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
I only had to casually ask MBUSA to add my 05 to the campaign and they did it. But I had added pigtails at 40-something thousand miles and so all I got were new pigtails.
Old Aug 31, 2012 | 02:08 PM
Hatchman's Avatar
Just got back from the stealership. All I got where the new pigtails/harness extensions, and got to keep my leaking sensors. Better than nothing, but I should have just gotten the extensions years ago since now there is no telling what damage is already done inside the harness.
Old Aug 31, 2012 | 09:10 PM
jetta02awp's Avatar
This is all I got also. I popped off the cover when I got home after reading the invoice that had listed "starter line" and "zip tie" but they detailed my car while they were at it not bad for free
Old Aug 31, 2012 | 09:31 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
Guys,
I had paid for replacing the engine harness due to oil leaking there. (this apparently was before they added my car to recall list)
Then I went to dealer several months ago to discover that they added 2005's to the recall.
Do you think I have a chance to get a refund from MBUSA since it's the oil leak from the recalled items that affected the harness?
And how does one talk to MBUSA?
Old Sep 1, 2012 | 06:46 AM
Hatchman's Avatar
Originally Posted by VVF
Guys,
I went to the MBUSA website and clicked on the "Contact" tab which led to a page you can email them directly. Took almost two weeks to get a reply, but that worked.
I would definitely try, since there is a chance they may pay for the repair, since they have admitted there is a problem by adding the 2005 to the recall. Good luck!
Old Sep 1, 2012 | 06:47 AM
Hatchman's Avatar
Yes, a free car wash and the extensions for free isn't bad, but I wish I had gotten it done before they started leaking into the harness.
While I was in the waiting room, I was drinking all the Keureg coffee, Coke, and pastries, so I left with a caffeine/sugar high!
Old Sep 3, 2012 | 02:39 AM
VVF's Avatar
VVF
Thumbs up
Thanks! I will write them tomorrow.
Old Sep 8, 2012 | 02:17 AM
Boom vang's Avatar
2019 C300 Wagon; '75 Triumph TR6; previous: 2004 C230 6spd sold after 17 years of driving
MB Canada still maintains that the problem/defect does not exist. I've replaced with the pig tails and an extra solenoid which was "leaking" even though there is no such 'problem' with this item
Old Sep 8, 2012 | 02:44 AM
Super Moderator
Same BS here!
Old Sep 8, 2012 | 10:40 AM
daiso''s Avatar
2005 c230 sport, k7 gsxr
We will get it soon.... but i already installed my pigtails
Old Sep 9, 2012 | 08:52 PM
Teekay's Avatar
C230k Coupe
Cam Solenoid recall
Hi Glyn
Hope this helps, I was able to track down the TSB that was issued through NHTSA website, here is the link below:
http://www-odi.nhtsa.dot.gov/tsbs/ts...intVersion=YES
It is the first 2 listed on that page, hope that helps. Please keep us updated.
Old Sep 9, 2012 | 09:15 PM
Teekay's Avatar
C230k Coupe
Old Sep 25, 2012 | 03:12 AM
RogerH's Avatar
C200 K Elegance Estate; Lexus RX350 Sport
Exactly the same is happening with my 2003 C200 Kompressor Estate - I think the engine is E18ML. Harness replacement, O2 sensor, Camshaft sensors. Does anyone know of a recall on this model?
Old Mar 30, 2013 | 08:43 PM
VVF's Avatar
VVF
Question
Hey guys,
after a short trip (~400mi) I noticed a slight oil leak (sweating?) at my camshaft solenoids, and also traces of slight coolant seepage at thermostat housing.
With my normal driving, I do not think I saw any leaks before. Certainly not the coolant.
The solenoids were replaced about 25k miles ago, and thermostat and o-ring 2 years ago.
I have the pig tails on the connectors.
Is it something serious or do I just wipe it off and keep driving it as usual?
The car is at 129k miles now.
Old Mar 30, 2013 | 10:42 PM
Boom vang's Avatar
the danger is not the leaking around the magnet but rather into the wiring. To me it does not look bad at all, maybe snug up the three bolts a bit, or buy a new O-ring and clean up around the area
Old Mar 31, 2013 | 04:09 AM
phister's Avatar
06 C230 SS 6spd
doesnt look too bad.. I'd clean it and tighten it up and see if it leaks again.
Old Apr 3, 2013 | 01:36 AM
VVF's Avatar
VVF
Thumbs up
OK thanks for the advice guys, I will report back if it gets worse. The wiring appears to be free of oil so far.
Old Feb 27, 2021 | 08:31 PM
BF_JC230's Avatar
2005 w203 C230
Added the pigtails years ago...
I was making a digital model of the m271 for a 1:18 project and noticed oil when I was snapping reference pictures...
So, I popped the pigtail ends - leaking magnets with oil on engine side -but no oil on harness side...time to repair.
car is 16years, 3 months old @ 90,000 miles.
Old Feb 28, 2021 | 11:39 AM
BF_JC230's Avatar
2005 w203 C230
Additional picture of oil in pigtail socket...
Old Mar 6, 2021 | 09:02 AM
BF_JC230's Avatar
2005 w203 C230
I’m informed that the leak is due to a failing timing chain...any insight?
I always start with no radio or HVAC to listen for chain, and occasionally start with hood up...I’ve never heard a thing to indicate a concern.
I do have the m271 cam holder tool set and plan to pull a chain through this summer regardless, as I hit 90k.
Thank you
