Starting Problems
Old Aug 23, 2012 | 04:41 AM
Polpol's Avatar
C270CDI
Question Starting Problems
Have a C270CDI 10yr old. Lately is very erratic on starting. On switch-on the indicators for the gearbox shift setting (W/S) and the gear position fail to appear and there is no attempt to actually start. There are various other indicators which do not appear to be correct (airbag check for ex.). Trying it a few (or more) times and it may eventually start. Thoughts are heading to either wiring or CPU problems. Anyone out there have experience or suggestion?
Old Aug 23, 2012 | 05:07 AM
phister's Avatar
06 C230 SS 6spd
How's your battery? There might be a wire grounding out.
Old Aug 23, 2012 | 08:57 AM
Glyn M Ruck's Avatar
Super Moderator
Look at all the starting problem threads recently posted.
In your case it might be the EIS but check everything else first. Also put your foot on the brake & move the shifter backwards & forwards a few times to make sure it is not the interlock switch. Remember it will only start in P or N.
Old Aug 23, 2012 | 04:43 PM
Polpol's Avatar
C270CDI
Have tried everything - releasing the shift and then back to P and still failed to start. Then doing absolutely nothing except turning the key a number a times before it may start - each time it fails it is also a case that the gearbox position indicator on the dash shows nothing (not even P) and then when I turn the key and the P is shown the engine will fire. My feeling is that either there are random failures of some signals to the control unit OR the software/control unit is not dealing with all the checks correctly. I have to say that I am doubtful that it is a wiring problem as, although the car is 10 years old, it has only done 48k miles and any wiring accessed is in good nick.
Old Aug 23, 2012 | 06:17 PM
Super Moderator
Does the car always crank over? Are you always able to turn the key?
If the car always cranks over then being a diesel one would more inclined to believe that the cause is electronic & your dash lights would tend to confirm this.
At your mileage there is no reason to suspect the injection system. When the car does start does it run normally? Can you hear the electric primary feed pump running under the back seat?
That's why unless it's a loose connection somewhere ~ or a failed start enable sensor ~ or no fuel pressure, I suspect the EIS (electronic ignition switch) might be the problem.
Otherwise all you need is fuel, air & crankover to start a diesel.
Old Aug 23, 2012 | 06:27 PM
Polpol's Avatar
C270CDI
- It never cranks over when the faulty situation is 'active'.
- yes to the first (perfectly!)and not sure to the second.
- any easy way to rule out the EIS?
Old Aug 24, 2012 | 09:11 AM
Super Moderator
OK - If it does not crank chack fuse 52 for corrosion & make sure it is 20 amp & not 15 as originally specified. Check the starter relay.
Have the EIS checked with a Star DAS.
Old Aug 24, 2012 | 09:13 AM
Super Moderator
See here for relays fuses etc.
https://mbworld.org/forums/c-class-w...-d2b-most.html
