E-Bay Smartkeys
I bought a key from e-Bay for $19. The seller said it could be reprogrammed, but based on what I read here, I sort of knew better.
I switched the 'guts' of the key with my own, and found that the hatch release button works fine (which was my ultimate goal anyway). But out of curiosity, I called MBUSA, and this is basically what they said:
MB Smart Keys are programmed at the factories for specific cars. 8 keys are made for each vehicle and use PROM technology to hold the encoded key data. This considered, they are one shot programs, and can not be altered. When your dealer orders a key for your car, it's one of the 8 originals. If someone should happen to lose all 8 or damage the ignition, then the entire ignition switch, 8 keys and the cars computer has to be replaced and reprogrammed for the car....specifically....uniquely...and again, only one shot.
Can anyone provide more details?
Oh well, nothing beat the look of confusion the other day when I let my friend drive my car. "Where do I stick this thing in? Where's the metal part?"
But this brings to mind a question - is there some bunker in Stuttgart where all the "extra" keys for each car are stored?
Or (more likely) are the unique codes stored in a computer somewhere and the PROM is programmed with the unique code when you ask for a new key?
--Steffen
the real question is that Is it really possible for some guy to lose 8 keys?
Erik
I've heard this before - at some point if you exhaust all the keys you end up having to spend $1000's to replace the computer.
--Steffen
Ok....so I did it...just for giggles
MB Smart Keys are programmed at the factories for specific cars. 8 keys are made for each vehicle and use PROM technology to hold the encoded key data. This considered, they are one shot programs, and can not be altered. When your dealer orders a key for your car, it's one of the 8 originals. If someone should happen to lose all 8 or damage the ignition, then the entire ignition switch, 8 keys and the cars computer has to be replaced and reprogrammed for the car....specifically....uniquely...and again, only one shot. Can anyone provide more details?
Hi Rick, can you be a bit more specific on how you switched the guts of the key? I want the hatch release button too DAMMIT
I'm sure the instructions have been posted before. Please do a search.
Now I have 3 keys.
Smart Keys could be there too
I also have a hard time believing that there is a limit on how many "starts" you get with a key, even if the number is as high as 10,000.
If anyone has any "official" info on this, please post it. Otherwise, I am just writing this off as urban myth.
Furthermore with that algorythem how could you ensure all your keys would be using the same number sequence to start the car?
So if you lose a key (that has yet to be exhausted) MB gives you a replacement for the one of the slots you already have, which necessitates sticking the key in the ignition for thirty minutes to five hours, at which time the car verifies it is a true replacement key and enables it with the current code (while at the same time it renders the key it replaced non-functional). Once a key is exhausted they send you a key for "slot" #3, which should work immediately without the "programming step."
With regard to the number of starts, I tried to search for the actual number but couldn't find it (although I did find one of my own posts that thought it was "25,000 to 100,000"). It's probably on the high end of this range, even if a car is started twenty times a day (which is a pretty high number of starts per day) then there will have only been ~36,000 starts after five years. Although, this could be as revstriker said an MBWorld legend.
I don't think storing the keys would be that difficult to do, With the amount of paper work they already need to store 6 keys would not be that difficlut, it would be one small box per car in a warehouse somewhere. This system is probable alot more secure then storing it on a computer by Vin do to the far greater ability to limit access to the space.
By the way, I'm sure most of the paperwork being stored is done so digitally. Plus, they probably have a purge date on the paperwork after so many years. With the keys, they would never be able to purge them.
It is actually a third key that I have, from a car that was bought back by MBZ. Now I have that extra key laying there.
$10 shipped.
Or you can come by and pick it up if you live near by. I am in Orange County, CA.
spacetrain.ca@netzero.net
Thanks.
We now know they would need to make and store 22 keys. Why would MB spend the money to make and store 22 keys for each of the hundreds of thousand of cars per year that they build? We are talking millions of keys per year. The cost would be enormous. The cost of storing the key data on a computer would be comparatively insignificant. And safer. How does a hacker get into a lan that is not connected to a phone line? Or a stand alone computer that is not connected to a phone line?
There are 8 keys possible per car, and for whatever technical (not policy) reason, they can't recreate a previous key. I can't remember the details as to why.
See: https://mbworld.org/forums/showthrea...threadid=44800
Could it be that MB just made 8 laser cut keys
