What would happen if I take the rear spring pad out completly?
Jason
could you be a little more clear on the problem?
so he didn't install the adjustable rear spring perch? or he did install the adjustable perch, but with no rubber spring pad?
You must have the new pad in, or you are metal-on-metal and eventually it will squeak. Look in the kit and see if you have a couple of extra 4 inch diameter rubber washers about .1 inch thick. Lucky you, the rears are easy to redo.
and the very thin new pad which comes with the new CO kit.
All i found was a really small round rubber piece. Does any1 have a pic of what the piece looks like?
It is only about 0.10 thick.
It is shaped like a simple washer with a lip in the center to mate with the center of the spring.
