CANBUS Hell
Old Dec 23, 2012 | 05:38 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
CANBUS Hell
So if you read my ClusterF^&K'd thread, you'll see i had an issue with the car dying after a big rain storm, and the cluster being blank.
This has happened once before, before the hatch got dented.
1st time it happened car went into limp mode, dash was dark,
headlights on constant. Also had a wheel sensor go out.
So took it to the mechanic, he couldn't get a read on anything, CANBUS was
going crazy. So, he parked it in the shop over the weekend, it came back to life.
The BAS module hasn't communicated for a long time.
But everything else did, and I have used Carsoft successfully in the past.
Now, it only reads the cluster, ME, EGS (trans) OCP (not sure what that is), & DB2.
I am wondering perhaps water is leaking through the windshield, since it was replaced years ago? What else could it be? I don't notice water anywhere.
So more recently it died completely, wouldn't start or turn over.
But then after a while, and disconnected
So, what would be the process for troubleshooting the CANBUS?
I found this CANBUS analyser online.
Everything in the car works, but i can't read the modules via canbus,
and I can't clear my SRS error, since it doesn't read the Airbags which I guess means, I have no airbags!!!!
It also doesn't read the SAMS or lots of other things.
HOW CAN I GET THE MODULES TO START TALKING TO EACH OTHER?
What would be the 1st step in troubleshooting this?
Odd thing is everything seems fine except the SRS error till you hook up Carsoft or SDS.
Old Dec 23, 2012 | 07:42 PM
mtnman82's Avatar
'16 E350, gone: '03 c230k
Do you have a 'decode' list of the CANBUS ID's, data link codes, and data in the messages for the Mercedes bus(es)? You're getting down into the 'bits' with this analyzer. CANBUS is the generic message format and interface protocalls for sending information - the end user defines the content of the messages, so you need the decode information for how Mercedes uses the bus.
If you do have the decode information, you need a way of tapping into the bus to monitor the message traffic. As far as getting the modules to talk to each other, you either monitor activity as the modules go about their business, or figure out how to talk to the modules from your decode information. I would imagine there are ways of initiating BIT's (built in tests) for modules, or sending a command a module is expecting to see and looking at it's response.
This is 'low level' stuff (i.e. the nitty gritty bits), and a DAS is programmed to decode/sort the low level stuff to make sense for an end user - kind of like a code reader decodes the bits and gives you the code # it sees and what that code # means.
Hope that helps...
I picked up the pn of the airbag module from Carsoft...
People say CS 7.4 is useless, actually it's pretty cool for what it is and much better than just an OBD reader, though I keep one of those in the car at all times.
PN is 0018209726
I found a couple on sale online, and here's where it's located.
Right under the center console.
Here's what it looks like. Now what?
Old Dec 23, 2012 | 07:47 PM
mtnman82's Avatar
Looks like we were typing at the same time... If you want to talk to the module on it's lonesome, you need a way of supplying power and hooking into the bus. Then you need the id, data link codes and message format/decode information for that module. When you have that, you should be able to talk to it.
Old Dec 24, 2012 | 12:07 PM
edgarinho10's Avatar
2013 UFO
Couldn't you just replace it?
Old Dec 24, 2012 | 02:49 PM
I'm trying to clear my SRS error.
Can't talk to most of the modules in the car for diagnostics.
Until I can fix the communication issues on the CANBUS
I won't be able to fix the SRS error.
So what I'm trying to figure out is how to fix it.
Whats the troubleshooting process for a 1/2 dead canbus?
Old Dec 24, 2012 | 09:06 PM
SunnyRayToronto's Avatar
2003 C230 Sports Coupe, Paprika Metallic Red, Auto, Pano, Leather
Todd,.... when I had issues with my ECU, my Mercedes Indy tested a number of things before making the call on the ECU, since ECU rarely go wrong. Anyways, when my Mercedes Indy tested my CAN-bus, he accessed it via all the wiring under the front part of the door sills an carpeting on the driver side. It's basically directly under the foot parking brake pedal,.... under that carpet where the carpet goes up to meet the door sills,.... there's a lot of wiring under there.
Old Dec 24, 2012 | 09:18 PM
Todd,.... before you check your CAN-bus,.... double check all your fuse, relays and wiring,.... make sure wire to grounds are properly connected. Make sure there's no water in those corner compartment of the engine bay where the battery and front SAM are. Also, in your front SAM and rear SAM,... "rotate" your relays - with key out of ignition, rotate relay with other relay of same colour and size,.... relay basically come in either black, grey, yellow,... full size or half size,... it'll help to label the relays in a X-Y grid pattern,..
Old Dec 25, 2012 | 12:07 AM
2013 UFO
Is there programming required for a Canbus?
I have a spare one if that is of any use to you...
Old Dec 25, 2012 | 12:20 AM
Glyn M Ruck's Avatar
Super Moderator
List everything on the car that does not work. I'm not sure you have a CANbus issue. Only an issue talking to it.
I've given you the layout for the different CANbus's & the guide that gives you an idea how to look for shorts etc.
Old Dec 25, 2012 | 12:57 AM
Super Moderator
The BAS/ESP module is mounted on the ABS block. Suggest you clean up all connections.
Old Dec 25, 2012 | 09:57 AM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
Just like any CAN based network, divide and conquer. I am with Glyn, I doubt you have an issue with the CANBUS, just an issue with a module or connection. I would unplug all the modules that are giving you problems, then plug them in one by one. I bet you have a module that is overloading the CANBUS due to a connection issue or hardware failure of some-sort.
Old Nov 4, 2019 | 07:37 PM
NikitaZ's Avatar
2007 Mercedes Benz S550
I technically have the same problem my 07 s550 which was actually finished in 05 wont start the dash and radio all work but no click nothing when turning the key it just turns and nothing I check the starter it works engine turns when shorting the wires but it also has a problem with the key being buggy and sometimes locking and unlocking the car sometimes not and the windows dont open except for the driver one then the tail or brake lights dont work then the display sometimes bugs out to and the radiator or ac fan run constantly when the car is off any help?
Old Nov 4, 2019 | 07:39 PM
NikitaZ's Avatar
Forgot to add that it happened when I drove it parked it then 2hrs later come back start it it starts then stalls I restart it and around 3 times it starts then stalls then completely quits starting and we checked the fuel pump no issues their and I checked all the fuses all the relays everything is fine
