Steering Wheel Controls/Horn not working
Old Jan 2, 2013 | 07:03 PM
aplotner03's Avatar
2003 Mercedes C240
Hello,
I have a 2003 C240. The steering wheel controls and the horn have stopped working. I've checked all the fuses and still don't know why it doesn't work. Has this happened to anyone or does anyone know how to fix this? Thanks.
Old Jan 2, 2013 | 09:20 PM
phister's Avatar
06 C230 SS 6spd
Its mostly likely one of the harnesses in the steering column or a crimped wire in it.
Old Jan 2, 2013 | 09:40 PM
aplotner03's Avatar
2003 Mercedes C240
Thanks for your input phister. I've researched a little more and have been reading about it possibly being the clock spring.
Old Jan 3, 2013 | 10:56 AM
phister's Avatar
06 C230 SS 6spd
if you need help heres a page with all the parts and diagrams of the steering column
http://www.mymercedesparts.com/parts...w=21&maxRow=10
Old Jul 15, 2013 | 10:44 AM
svega4290's Avatar
03' C230 Kompressor | Past: 07' C230 Sport, 04' BMW X3
Did you find out the solution to this issue? The right side on my c230 coupe is completely dead both phone and arrow buttons alongside with the horn is not working.
Old Jul 19, 2013 | 02:16 AM
dineshh's Avatar
Mercedes GLA45 AMG
Same problem; I fixed it on mine last weekend after reading this thread. The connector came off and had to solder it back on to the PCB:
https://mbworld.org/forums/c-class-w...-controls.html
Old Mar 16, 2014 | 05:44 PM
mbjt123's Avatar
g500
Problem !! Not working horn control panel and srs message
I car recently was repaired a new evaporator and another part for a/c was changed, now I have problems with control panel, the horn is not working and the air bag problems, plus a red light came up srs problems. Can you tell me what happen??/
Old Mar 19, 2014 | 01:54 AM
dineshh's Avatar
Mercedes GLA45 AMG
Not sure this is a related issue with the steering controls; unless they removed the steering wheel to carry out the repairs. Otherwise, it may have to do with the removal of the center console *not sure about the horn* but I have had the SRS warning light go off when installing a Head unit.
Old Mar 20, 2014 | 10:17 AM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
if you look on in the world .org you will find instructions on how to repair the switches. fact is the solder joints go bad and you need to simply heat up the solder joint and put the switch back in and it will be fixed. I had the same problem and I was able to fix it in this manner. definitely not the clock spring. basically you remove the air bag / horn button and then remove the switches from the airbag module. it's not hard I did the whole job in about a half an hour to an hour since I didn't know what I was doing
Old Mar 20, 2014 | 10:21 AM
I was trying to say earlier benzworld .org<br />
<br />
Originally Posted by C230 Sport Coup
if you look on in the w<br />
