Just bought my first Mercedes, need help with some issues
Has a couple of issues I have indentified if you guys would like to help?
First issue (and main one):
The steering wheel wobbles quite violently when braking when doing from 35-55mph. I've read online this may have to do with my ball joints/arms/bushings? Also, the car was sold with two bald tires on the right side and two okay tires on the left....
My digital speedo is a lot lower than my analogue speedo. I was cruise controlled at 79 and the digital one said I was doing about 48? I checked the settings and it says MPH is selected, so this confused me.
My A/C turns on, and I can hear it blowing air, but no air is coming through the vents? At all, so I am assuming the air filter, cabin air filter (engine), and cabin air filter (inside car) needs to be checked and changed for blockage? The vents are not closed, BTW.
Thanks so much for the help, I really appreciate.
as for the speedo make sure its checked on mph for sure, sometimes it might be choosen but make sure its really on it. also make sure your speed sensor is connected and right.
for ac make sure the stepper motor is working right. change your filters, even though they shouldnt really be the issue if they have never been changed its good to do so or your car will smell musty and moldy.
As for the speed/ac I'll check out what you suggested thank you.
If your car isn't still under extended warranty, I'd suggest taking your Benz to a local independent mechanic if you can; will save you a ton of money, even if you have to do a rental instead of a loaner.
Also check your vent direction knob and make sure that it's set to 9 o'clock to get the vents blowing on full. Sounds obvious, but thought I'd add that anyway.
