Whining Noise
Old Feb 13, 2013 | 12:01 AM
DaODB's Avatar
2004 C320
Whining Noise
I am in a toss up here, and don't want to throw an expensive part at my car to try to get the fix.
An independent Mercedes dealer, my local mechanic, and Autozone said it is my Power Steering Pump. All said so just from observation and no tests. I went back to my local mechanic after getting prices to make sure, and he took belts off and still came to the conclusion that it was the Power Steering Pump for some reason.
Mercedes-Benz of Orange Park said it was my A/C Compressor, and another independent dealer said the same. They both used the "ears".
My friend also told me that Tire Kingdom does free diagnosis, so I told them the previous statements, and they took it right back in the garage and took off the belts and came back and said that they spun the pulleys and thought the Tensioner Pulley was acting funny.
The symptom is a very loud, distinct whine that can be heard from around the corner. My roommate can hear me from inside the house when I am pulling in. The only thing that factors into the noise are RPMs, which makes me very hesitant to say it is the Power Steering Pump and A/C Compressor. No sound difference in turning the wheel (unless it's all the way to the full extent, which sounds like a piston going off or a hiss), and the A/C being on or off has nothing to do with it. Only RPM. I have already changed my Power Steering Fluid with no results, too.
Any ideas? I'm sure this has more to do with the transmission since it is automatic on an incline, but when I go up a hill, it kicks up to about 2000-2500 RPMs before switching gears which makes it really loud/embarrassing!
Thanks!
Old Feb 13, 2013 | 12:11 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Someone should use a mechanics stethescope on all the components in turn which are running on your serpentine belt.With a noise as loud as that you should be able to pick it straight away.
They can be had on E bay for about 10 bucks.
A long handled steel screw driver to the ear should determine it too. Make sure you hear it yourself for your own piece of mind. After all you will be paying the bill!!
Interesting to hear which mechanic has got it right !!
Old Feb 13, 2013 | 12:15 AM
SunnyRayToronto's Avatar
2003 C230 Sports Coupe, Paprika Metallic Red, Auto, Pano, Leather
Right now it's all he said, she said,.... but we don't know what the car said!
Let's hear what the car said. I would suggest you video record with audio that whining sound under the hood,.... post it on YouTube and provide link here.
I'm sure someone here is good at identifying whining sounds,..... the only whining sound I'm good at identifying is the whining sound coming from the wife!
Old Feb 13, 2013 | 08:14 AM
Javvy's Avatar
13 Jeep JKU Sahara w/4" lift Kit & the works,2015 Toyota Sienna XLE,2013 Hyundai Sonata Hybrid
:r olf:
U can also find the mechanics stethscope on Harbour freight .....
javvy
Old Feb 13, 2013 | 10:09 AM
Crna Mechka's Avatar
12 E350 4Matic Sport
Could very well be the power steering pump. Does the noise get louder when you turn your wheel to full lock left/right? If so, then it's probably that pump.
Otherwise it could be the belt tensioner, idler pulley, alternator pulley...etc. anything related to the belt system could be the likely culprit.
Like someone above mentioned, get a mechanics stethoscope and check the parts one by one. If you hear any abnormal noise (clicking, grinding, skipping) on any of the parts it's time to replace it. I just got done replacing the tensioner and idler and have yet to get to the alternator pulley.
Old Feb 13, 2013 | 05:35 PM
DaODB's Avatar
2004 C320
hahaha that wife joke, too funnyI'd say that's more annoying than my car, though
Here's a video:
The sound seemed to cut out when making the video. I'm just sooo popular getting too many messages at once
An observation my roommate made is that the tube that goes from the power steering pump to the front (next to the wiper fluid reservoir) was shaking when I put the wheel in full lock. I believe that's what that tube was, I think I recall emptying it when doing the PS fluid flush.
Sorry the video became so poor. Let me know what you all think.
Thanks!
Old Feb 13, 2013 | 07:42 PM
Glyn M Ruck's Avatar
Super Moderator
It sounds like a tensioner or idler pulley (or a bit like a torque converter) but the noise seems to be coming from the front of the engine.
If you remove the Poly V belt & start the car does the noise go away? That is check no one.
If the noise goes away then you find out which accessory or pulley is making the noise.
As JC suggests an engine stethoscope will help.
Old Feb 13, 2013 | 08:07 PM
DaODB's Avatar
2004 C320
Hey Glyn!
Yes, the noise undoubtedly comes from the front of the engine, and I am pretty sure from the right side (if facing the car).
By now I believe you know I am terrible at mechanics. Is it easy to remove the belt?
I just did a search on Harbor Freight Tools and found that there is actually one not too far from me. Even though I am low on money this month from shelling out for a new alternator, the Mechanic Stethoscope isn't too expensive and I have been curious to this noise for 4 months now! I'll probably head up there this weekend, or maybe even tomorrow if I find time, and pick it up.
Thanks!
Old Feb 13, 2013 | 09:51 PM
Super Moderator
These are usually about $10.
Old Feb 14, 2013 | 01:11 PM
DaODB's Avatar
2004 C320
Well, shows my mechanic inept. Was observing what sounded like nails on the chalk board on each piece, decided to check the steering pulley again, and the metal piece goes flying. The coolant tube got hit by the front AC fan but didn't penetrate, but looks half way deep. I stuck that tube back in its little slot. I guess I should just give DIY's a break and always take my car to the shop...
Old Feb 14, 2013 | 02:22 PM
Carsy's Avatar
Sorry to hear that.
Best investigate if coolant hose needs replacing .
It will be expensive it coolant leaks & engine overheats.
Interested to know what noise is when you find out.
Old Feb 14, 2013 | 04:35 PM
DaODB's Avatar
2004 C320
Just got back from the dealer, and was advised to replace it because the threads are showing on the tube.
Are there any alternative places I can purchase this? I couldn't find it on Autohaus
Old Feb 14, 2013 | 08:15 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
Parts.com has the hose for $38. Check this link:
http://www.parts.com/parts/2004/MERC...iagram=5775066
Old Feb 14, 2013 | 10:28 PM
DaODB's Avatar
2004 C320
$38, not bad.
So clearly the coolant hose should now be the #1 priority over a strange noise. I was becoming paranoid the noise was a belt tensioner and that it will eventually pop, though, and with my upcoming 3 hour road trip, that's the last thing that needs to happen!
I've already observed the hose and 2 things have caused a worrisome for me. 1. In my picture of the diagram, #55, that part seems very difficult to connect. Any tips? 2. Will the coolant fluid leak out? Like I said, I'm low on funds, so if this is over a $100 fix then I might have to just walk for the rest of the month.
Right now the car doesn't seem to be causing any troubles with the semi-torn hose, and the farthest I drive in a trip is 8 miles total (around campus). The farthest place in town that I actually go to is the Mercedes dealer which is probably 12 miles there and back.
Thanks!
Old Feb 15, 2013 | 01:27 AM
Carsy's Avatar
The hose needs replacing but short term you could tape it up firmly with a good quality tape & monitor it very closely for the month.
Yes, you will loose coolant some when replacing( not a lot ) so you will need to buy the correct MB coolant.
The hose clips look none replaceable so you will need a couple of quality generic hose clips too . Take a look where the other end is.
Another option is that you could cut out the worst of the damage & put a quality elongated joiner in , clamping it with hose clips. It will need to be done properly.
Good luck.
Old Feb 18, 2013 | 02:26 PM
Carsy's Avatar
DaOBD ,Whats the outcome ?
Old Feb 18, 2013 | 04:31 PM
DaODB's Avatar
2004 C320
I know how it is when there is a dead end post, I won't let this become one if I find the solution! But I am just waiting, have been given criticism that I am a BIOLOGY student, not mechanic. Lol. But I am maintaining, walking and sandwiches until March comes. I called around and seems the indendent Mercedes shop has best deal, $170. I am only going to replace the upper hose.
As far as the noise goes, I expect tire kingdom to do me well like they did last time. So that will be during spring break when I am back in Jacksonville. Expect a post around middle of March about the noise.
Thanks for checking up. Means a lot!
Old Feb 26, 2013 | 04:02 PM
DaODB's Avatar
2004 C320
Hey all, just wanted to give a slight update. I ended up splicing that hose together, seems to be going good. Headed to Orlando this weekend though, so I guess that will be the real test.
I have been noticing a vibration in my car. Did a quick search, and was terrified it might be my engine mounts. Then saw a little test and was happy to see that the engine didn't seem to move at all when I had my roommate accelerate in reverse and drive.
But, what I noticed today was there were no vibrations when I drove with the AC off. I got home and realized this, turned it on, and then the vibrations started. (Most noticeable on the Auto mode) Could this correlate to the diagnosis of the shops saying the whining noise is the AC Compressor? Or tests still need to be done considering all are connected from the belt mechanism?
EDIT: The vibrations seem to be intermittent, most noticeable while at a stoplight. Did still feel it in neutral in my driveway, though, so thinking it has to do with the belt system.
Old Feb 26, 2013 | 04:16 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
What kind of viration?
1. Vibrate as you slowly let go of the brakes from a stop?
2. Vibrate on idle in park?
3. Vibration while driving?
4. Vibration at stoplight with foot on the brake and in Drive?
Whining noise, does it;
1. Whines when you turn the steering wheel?
2. Whines Only when steering is at full lock?
3. Whines only when you turn on the ac?
P.s. Been a long time someone new to the forum actually posted something comprehensible when asking for help. Kudos!!
Old Feb 26, 2013 | 04:43 PM
DaODB's Avatar
2004 C320
Thanks, I think I am pretty good with my words. Haha
But, the vibration is pretty prominent. a passenger has felt it before, and previous to all of the posts and observations I just said it was the Power Steering Pump. But after reading more it sounds like it can be much deeper than that.
The vibration seems to be off and on, even if I am in park I can feel it. It is nothing serious, but definitely can be felt. And the AC being on amplifies it.
At a stop light, I can feel it through the brake pedal. The steering wheel also shakes a bit, but lets off once I accelerate. So it applies to 2 and 4.
The whining noise is dependent on nothing else besides RPMs. Sounds like a supercharger, and found BMW videos that sound the EXACT same which the outcome came out to be the tensioner/idler.
Can a bad tensioner/idler cause vibrations?
EDIT: My Indy mechanic was shocked out how rough it was at idle. At a stop light I notice it at about 500 RPM. Also, let it be known that a long time ago (about a year) the shifter bushings were in "caution" from the dealer saying I needed to replace them. I have not done so.
Old Feb 26, 2013 | 07:36 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Vibration is most likely due to misfire. You will probably see pending error vodes if you get a code reader. The coil packs tend to be the culprit.
Whining noise if depends on rpm then yes, the bearings probably seized.
Old Feb 26, 2013 | 08:05 PM
DaODB's Avatar
2004 C320
Last time I took it to the mechanic to have him clear Check Engine and install MAF he said there were no other codes besides that.
Just got back from the library and felt strong vibrations again. Auto AC in gear seems to cause most vibrations. Auto AC in park still vibrations, but not as heavy. No AC on is very slight vibration, hardly noticeable at all.
I am still planning on getting the tensioner/idler checked over Spring Break.
Any dangers of driving the car under these conditions?
Honestly I don't care if the car runs rough... I just don't want to take the highway to hell...
Old Feb 26, 2013 | 08:10 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Ac compressor is driven by the engine. When it engages, the rpm drops, and if you already have a minor misfire it is going to be more appearant.
Some code reader will not show pending codes. Only codes that throws a check engine light. A slight misfire will not throw a check engine light. Get a code reader that will show you the pending codes or go to a mb mechanic that has the STAR.
Once you find out which cylinder is misfiring, check the ignition wires for resistence. Pretty common to see ignition wire go bad and causes misfire.
Old Mar 6, 2013 | 12:51 PM
DaODB's Avatar
2004 C320
Wow, so after being embarrassed at the drive thru by hearing the worker go "Do you hear that awful noise?", I began researching again. It very well does seem like this could be the AC Compressor.
Considering I will only have this car for 2 more years, and the value is dropping on it more and more, how does a bypass belt sound? Even though I live in Florida, I am not so sure I want to pay, what, $1500 for it!?
Thanks!
Old Mar 6, 2013 | 02:16 PM
syfi's Avatar
2005 Crossfire Limited N/A & 2005 Crossfire SRT6
Thanks!
Go to LKQ and get a used compressor. Shouldn't run more than $300.
http://www.lkqcorp.com/search-inventory.aspx
Actually, the new ones are about the same price!
http://www.fcpeuro.com/Mercedes~Benz...004&m=20&e=630
