car cranks but will not start
Old Feb 14, 2013 | 04:43 PM
piwito's Avatar
2003 C320
Hello,
New to the forum...and thanks to all the contributors.
Have an '03 C320, been having a starting problem with it....first time shop replaced crank position sensor, it work for a couple a months, then it happened again, took it in, shop replaced fuel pump it work for about six months, yesterday it did the same thing. Car will turn with very rough idle and then it turns off. Any ideas as what could be the problem....thanks.
Old Feb 14, 2013 | 07:21 PM
Glyn M Ruck's Avatar
Super Moderator
Check fuel pressure at the Schrader valve on the front fuel rail. s/b > 3.8bar or 55psi while cranking.
Check all vacuum hoses.
You might have another CPS failure. Did you use a genuine unit? Always check most recenty disturbed items first.
Good luck!
Old Feb 18, 2013 | 02:28 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Piwiti, Has it started ?
Old Feb 26, 2013 | 12:32 PM
piwito's Avatar
2003 C320
Update
Update:
I checked Schrader valve for pressure by pressing with a screwdriver, and there was no pressure.
So, I decided to check both the fuel pump (passenger side) and fuel level sending unit (driver side) for any signs of a bad connections or for something that did not look right. The only thing I noticed on the electrical connection of the fuel sending unit was a brown spot on the plastic cover that cover the 6 wires that connect to the unit and also the rubber seals (Blue and Red), that I guess is to prevent the gas from getting in to the electrical connection, they were all coming apart and breaking down….see picture. So, my question is, Could it be that the unit shorted out because of the gas getting in the connection? I am waiting for the rubber seals to plug it in again and see what happens.
Old Feb 26, 2013 | 01:00 PM
Super Moderator
I suspect that the fuel pump has failed. When last did the car have a fuel filter?
Good luck!
Old Feb 26, 2013 | 02:21 PM
sinister55's Avatar
C55 AMG, BMW 535i, Mazda Cx-7, Nissan 240sx
Things to check, Fuel Filter, Crank postion sensor, MAF sensor, injectors.
Old Feb 27, 2013 | 12:32 PM
piwito's Avatar
2003 C320
Yes, CPS and Fuel Filter have been replaced. One thing to add is that when I checked both fuel level sending unit and pump, both tanks were completely empty. Besides these units what could cause for the gas not to flow.
Thanks....
