zerex coolant
Engine temperature is controlled by means of a mixture of coolant and water. That mix can very between 40-60%. Mercedes Benz and most other European manufacturers use a special coolant standard known as G05. G05 coolant usually comes in a yellow color and features some unique benefits (hybrid organic, low silicate, phosphate free).
For the most part, vehicles 2002 and later specify a cooling flush every 15 years or 150,000 miles. Mercedes 2001 and earlier are every 3 years. There are exceptions in the transition years. Later production vehicles with 15/150 service interval have a silica gel packet in the coolant reservoir that constantly replenishes the silicate concentration in the Mercedes Benz coolant helping to promote the long life. If you top off with another type of coolant such as OAT (organic acid) or phosphate based you are contaminating the factory coolant system.
so zerex is low silicate. mercedes 02+ theirs a silica gel gacket putting siilcate into the system. now my question is...
does mercedes coolant have more silicate than zerex?
Have you seen coolant and the accompanying debris after 3 years in a car? No, I don't think you have, otherwise you would be posting up 15 year coolant absurdity.
Kid, STFU.
and my not giving advice u dumbass im asking a question
get off the drugs
No, I don't suffer the fool.
Whereas Zerex G-05 is good for 5 years or 150,000 miles; Mercedes claim coolant is good for 15 years because they use the silica gel pack,.... but then again, these are the same guys who told you your transmission oil is sealed for life and you never need to change your 722.6 transmission oil,.... as long as you're in North America since the exact same transmission oil behave differently in North America and RestOfWorld! So regardless of silica gel pack or not,.... best to flush and change coolant every 5 years.
STFU???,.... oh, Shut The Front Door!
Now, everyone go have an oreo and be happy.
15 years is a long time for any water based system, and even with the timed released silica, it is hard to prevent the solution from becoming depleated.
Zerex is a product designed to sell water pumps, thermostats, hoses, head gaskets, & heater cores.
Kid, STFU.
BASF makes the OE coolant. It is a controlled silicate formulation that will last 15 years with silicate top up from the silica gel sachet in the surge tank. The primary additive system is non depleting.
As long as the coolant in your system is clear & bright on newer Benz models the coolant is fine up to 15 years.
Zeroing in, my issue is not that the coolant can't be used for 15 years. I'm not a fluids engineer. However, I can say that in using the OEM fluid, on year 3, I required a hose change. When I drained my stock OE antifreeze that stuff had so much debris in it that I started doing tranny flushes every 30 odd months. Am I implementing overkill. Perhaps, but 240k miles on a modified M111 pushing a Kleeman kit tells me that my maintenance plans and implementation has its rewards.
There are a number of things that MB USA told us about our cars that have been proven inaccurate. Some noted above.
Its 10:10 in the morning Pacific time. Sammie is still the last guy I would go to for mechanical advice.
Ed
Our recommendations across a broad range of applications are.
XYZ is recommended for use out to 750,000 miles/15,000 hours/8 years. If even longer service intervals are desired then the addition of ABC at 500,000 miles/10,000 hours/4 years will extend the service life to 1,000,000 miles/20,000 hours/8 years.
Are we being cautious ~ sure but we clamp at 8 years.
Benz knows it's cooling system componentry well hence their comfort at greater changeout interval.
If you were planning on keeping your car for 15 years how often would you change the MB coolant?
When changing the coolant should we remove the silicate satchel & if so where is it?
I wonder whether MB sell the satchel ?
is it possible this shop put it on wrong?
what would the coolant temp do with no thermostat?
I think it is important to top up over the years with the correct MB coolant & demin water .I top up with about 50 to 80 ml /year to maintain the level.
Generally with no thermostat these cars would run too cold.
Your method guarantees adequate concentration if you are not checking with a refractometer.
I've read about "liquid glass" products sealing head gasket leaks. I read that at least one manufacturer would add this routinely to cooling systems as a preventative measure against head gasket leaks.
I wonder if MB is doing the same?
