Transmission and Engine mounts collapsed
Old Mar 8, 2013 | 12:22 PM
jaroms10's Avatar
Merz C240 2002-2003
How to replace the engine and transmission mounts on my Merz C240 2002 model?
I brought to the dealer and they diagnosed that the mounts were collapsed
and the rear right axle seal was leaking! Any help please?
Old Mar 8, 2013 | 12:46 PM
Glyn M Ruck's Avatar
Super Moderator
See W203 Wiki here under M272 engine. Pretty much the same for M112.
https://mbworld.org/wiki/index.php/W203
Old Mar 8, 2013 | 01:41 PM
jkowtko's Avatar
2005 c230SS
I can't help you with the front engine mounts or rear axle seal, but the rear transmission mount was pretty easy to replace. In addition to the service manual pages you can search for 'transmission mount diy' on this and other forums and you should find explicit instructions.
Old Mar 8, 2013 | 02:32 PM
Super Moderator
Front & rear are in the Wiki.
Old Mar 8, 2013 | 02:39 PM
jaroms10's Avatar
Merz C240 2002-2003
Thank you that's very helpful
Old Mar 8, 2013 | 03:07 PM
Super Moderator
We also cover how to remove the bottom plates etc. etc.
Old Mar 8, 2013 | 11:48 PM
WaveyKat's Avatar
Something Slow
this might help too:
https://mbworld.org/forums/clk-class...or-mounts.html
https://mbworld.org/forums/clk-class...cabriolet.html
Old Mar 22, 2013 | 09:57 PM
jaroms10's Avatar
Merz C240 2002-2003
shock absorber removal front
any idea how to remove the shock absorber of Merz c240 2002 model
I did remove the nut on the right but I don't know the left side if it is clock wise or counter clockwise
any help
