Cassette Tape "stuck"
I have read multiple threads on both here AND other MB sites, and haven't found a solution(other than taking radio out)
I have a cassette tape-to-AUX that hooks into my phone so I play music. I've been using it for nearly 7 months now with no problem, and last week I put the cord into my phone and a message came up saying "Tape Stuck". Tried ejecting tape, nothing. Tried switching modes and back to tape, nothing. The past 3 days I've done many things I've seen suggestions on; pushing on the bottom part of it, prying it from the top, etc and can't get anything to make the thing pop down.
Does anybody else have suggestions, other than taking the radio and dash completely out? I am anticipating a 3 1/2 hour road trip on Saturday(my H.S. soccer team made it to state) and would love to have it fixed by then...
Thanks in advance.
Thanks in advance.
I drive a Toyota Hybrid...
try to get a new tape adapter see if it help, if not replace your tape deck isn't hard at all. only took me 20mins to an hour with only breaking a few clips
There are two things I would try prior to taking the dash apart.
1. Remove fuse 64 (10A Red) from the fuse location under the hood on the drivers side. Allow about 5 minutes for the Radio processors to lose their mind. Then plug the fuse in and try to eject the cassette.
2. Open the cassette door and blow clean dry compressed air into the slot. There is an infrared sensor system that looks for a cassette. It might be dirty, and hopefully the air blast will move the dust bunnies.
If this does not work, get out the tools and start with the center vent, then switches, then shifter cover, then climate control then the head unit. You can find detailed instructions on the site.
The problem is I can't open the cassette door. I'm sure if I can get that open, somehow, I can get the cassette out... but I've tried nearly everything I've read and I can't get it open.
Hope this helps,
Tim
Similar thing happened on my C230, I was able to get it out eventually. I'm sure you've tried this, but try it again. Hold down the eject tape button with one finger, while pushing really hard on the bottom of the tape screen. At the same time, shove a ruler or something else in the top of the tape area and lift up on it while pushing it in. The combination of these three things finally made it open, and I was able to take the tape out and replace it with another one that wouldn't trigger the "tape stuck" screen.
Hope this helps,
Tim
Hope this helps,
Tim
