Hello all! Hope all is well.
So Rallye Mercedes in Long Island is doing free checks and they recommend services that are needed.These were my results. The cabin filter and brake fluid aren't really my issue. Its the oil leak in my engine. I will take pics of the engine tomorrow, but this is the printout.
Thank you!
Thank you!
Quote:
what to do?Originally Posted by Shifter
Noted as oil seep, not leak fyi there is a difference
Not sure if the diy is available on this site, but the first breather cover seal replacement procedure I found came up here:
http://www.benzworld.org/forums/w210...passenger.html
I need to get around to this too, its not leaking profusely, but seeping slightly, from the pics it seems to be a pretty simple diy if you're inclined to do it yourself.
alright thanks yeah i was looking for a DIY couldn't quite find one. THank you Drummajorc
Tru Taing - John did a complete DIY on resealing the crankcase breather recirc. cover.
Where?
ExploreGood, ole stealerships
You could go to the Bahamas when you don't give your hard, earned to them
Quote:
Here in the Wiki. Originally Posted by Akhafeez
Where?
https://mbworld.org/wiki/index.php/F...org_Forums.pdf
THanks so much! I will do that this weekendOriginally Posted by Glyn M Ruck
Here in the Wiki. https://mbworld.org/wiki/index.php/F...org_Forums.pdf
Currently Active Users (1)
