m271 guy's who've done your timing chain
I want to do this soon, but don't weld or anything so can't make my own tool. Is there another cheaper tool out there I can use? Or what methods have you guys used?
).I also found this: http://www.tooltopia.com/otc-tools-4744.aspx
It's a little expensive for one chain. I also found a bunch on ebay (search for chain breaker) that are less expensive. They are mostly for motorcycles but some may work with our chains.
Good luck!
Also I believe the user VII on this forum has the chain retainer thing, maybe he will be kind enough to loan the tool: https://mbworld.org/forums/members/198424-vii.html
Class Action?
Class Action?
I just don't understand how an 05 c230 jumped time with 60k miles
Is the head shrinking? are the bearings on the cam wear or the place elongate where they are in?
Quite simply it was an engineering mistake by putting 1 gear and a single chain rather than a double chain which every car company does when they use a chain rather than a belt
I asked around in the Toronto area about knowledge of chains jumping or stretch and have their been any problems and the answer was no, never heard of this problem and "we see a lot of cars in" however this was a similar response to the infamous cam solenoid issue which has a recall everywhere else except here.
The problem with this issue is like a light switch either on or off and when it jumps it is death to the motor. Start up sound should give you a warning however hard to tell if it is the cold start valve making the clatter in the first couple of seconds (which has been like that since new) or is is the chain
Ha! my 800th post (a far cry from Glyn which is 20x that amount)
This engine should have been fitted with a duplex chain!
Dealers talk nonsense.
Glyn, I saw a master link listed on the MB instructions for replacing the chain, but then they also list the crimping/smashing tool and the other link too if I remember correctly. A master link sure would make things easier...
Probably did it the hard way, but it worked.
Oh thanks Glyn, NOW you come up with that suggestion
It was still slightly off the second time but the ECU was able to compensate for it that time, it was barely off though, but was enough to pop a CEL. ECU compensated after a day or 2 and I just reset the CEL and it never came back.
Sold it like a month later (about a year ago) and the guy I sold too has apparently been auto-crossing it on the weekends with no problems.
