03 c240 pass seat 30amp fuse blowing!!
Old Jul 17, 2013 | 08:25 AM
contact148's Avatar
2003 c240 4matic wagon
well all of a sudden the front passenger seat thats allmost NEVER moved the 30 amp fuse keeps blowing for it it blows randomly and by itself IE the seat is NOT being operated and it blows so I have a short any ideas???
Old Jul 17, 2013 | 12:33 PM
samaritrey's Avatar
Super Moderator
THE C350
I would check the control modular under the seat for damaged wires. If everything looks fine I would unplug the modular and see if it stops blowing. Does the fuse blow the second you replace it or does it take time also does the seat work when it has a good fuse in it? Is there anything else that is powered by that fuse?
Old Jul 17, 2013 | 02:02 PM
contact148's Avatar
I'll check all that out tonight. This seat was working fine my wife never moves it I went to raise it and the fuse was blown I replaced the fuse the next day but never checked it for operation. Tried it this am and it was blown again
Old Jul 17, 2013 | 03:47 PM
Moviela's Avatar
Heated seats? Unplug the seat element. They have been known to short.
Old Jul 17, 2013 | 05:50 PM
contact148's Avatar
ok its fuse #1(seat adjustment passenger) rear fuse panel 30 amp green Only the seat is listed on that fuse
got home looked at wireing moved it around a bit replaced fuse
seat moves as it should
seat heater works (I think its like 40 out)
started car still works
going out later try it again then
seems seat heater is fuse 25,41 different fuse
Old Jan 18, 2014 | 09:48 AM
contact148's Avatar
up date on this its still blowing the fuse some times it lasts weeks
fuse is currently blown and seat heaters work fine
could one of ther seat motors be shorting??
this car has manual controls to move seat back and forth but power for the back and seat height
Old Jan 20, 2014 | 08:39 AM
Eemo1's Avatar
2003 c180 Kompressor Sport
Best bet is still the wiring. moving the seat around/ changing the position might move the cabling enough to make contact if the wire is worn in any place. doesn't take, but one hair on the cable braid to make contact...
also, search works too.
example: https://mbworld.org/forums/c-class-w...owing-out.html
