My 19" LM5's Don't Fit my C 230. LUGS QUESTION???
Old Sep 4, 2003 | 05:17 PM
PimpedOUTride78's Avatar
Question My 19" LM5's Don't Fit my C 230. LUGS QUESTION???
Hey i bought the Rims off an owner of an S Class. I have a C 230 sedan. I called CEC and they said the Lugs on the Rims are too big or sumthin for my C Class and that i have to order Lorinser Lugs which are another 4 bills and i do not want to do that. Does anyone know if Kragen or any auto store will have the lugs i am looking for??
Anyone that has AOL or AIM and wants to help me out please im me at: Azntigar78@aol.com Thanks a lot. Peace
Old Sep 4, 2003 | 05:54 PM
BrabusCClass's Avatar
GL450, Sienna SE
call TWS and ask them. Maybe they have some lugs there. www.thewheelsupply.com
Old Sep 4, 2003 | 05:58 PM
SiLvaC32's Avatar
C32
4 bills for lug nuts??
try anywhere that sells wheels, they can custom make some lug nuts for ya!
Old Sep 4, 2003 | 06:09 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
I know that the Cs use 12 mm. Don't some other MBs use 14 mm?
Old Sep 4, 2003 | 07:34 PM
jo17jC230's Avatar
2008 C300 Sport
NO kidding!!! 4 bills for lug nuts?????? thats insane!!
Old Sep 4, 2003 | 08:40 PM
netboy's Avatar
2003 C320 coupe/c450 in Feb 2016
i guess i'm lucky.. my 19" wheels came with lugs nuts..
Old Sep 4, 2003 | 11:16 PM
Hey, is that 12mm total length for the lugs?? Thanks a lot
Anyone that has AOL or AIM and wants to help me out please im me at: Azntigar78@aol.com Thanks Peace
Old Sep 4, 2003 | 11:18 PM
Old Sep 5, 2003 | 05:40 AM
Lynn's Avatar
12mm or 14mm is the radius of the hemispherical ball seats of the wheel bolt holes and the ***** on the lug bolts. You can't use a 12mm bolt (C class) with the 14mm bolt holes in the S class wheels. They will not have enough clamping force and the bolts will loosen and the wheels may fall off. You should be able to buy proper bolts at the dealer or most tire shops. You might have to have the bolt holes in the hubs re-tapped. I'm not sure about that.
Old Sep 5, 2003 | 02:57 PM
KMAN's Avatar
02' c230
It is not $400 dollars for lugs, all Lorinser wheels are made at a certain offset and use adapters and lugs to work on a certain chassis. That is why you are able to purchase LM5's off a S-Class and use them on your c230 (assuming you have the right hardware). When somebody buys the wheels they come with all the hardware. You need to purchase new hardware if you are using the wheels for a different application than they were purchased for. SO it is not $400 for lugs it is for all the lugs and adapters.
The reason that Lorinser does this is so you can use the same wheels on different chassis unlike AMG or factory wheels. YOu could not take AMG's off the S and run them on the C.
Hope this clears it up some.
Old Sep 13, 2003 | 06:21 AM
CarlssonCRS's Avatar
r171
kman: dude do you know what youre talking about? the rims have nothing to do with the chassis. obviously s-class rims wont fit on a c-class cuz its a different offset. you can buy a spacer which enables you to use different offset rims on your car. this is probably what lorinser was trying to sell you for 400.
Old Sep 13, 2003 | 10:38 AM
jeffj's Avatar
2004 CL55 AMG
this is great information....thanks!
Old Sep 15, 2003 | 11:00 AM
KMAN's Avatar
02' c230
carlssoncrs,
since I work for Lorinser I think that it is safe to say that I know what I am talking about. You contradict yourself saying the wheels having nothing with the chassis but they have different offsets. The wheels and there offset determine which chassis they will work on. So how can you say the wheels(rims) have nothing to do with the chassis. Each factory/amg are made to a certain offset to work on a certain chassis and require no additional hardware. If you read my reply I am telling this member that Lorinser does not make there wheels that way. They make it so that with the proper hardware you can take any Lorinser wheel and use it on any chassis.
maybe you did not read careful enough, next time read better then challenge people on their knowledge.
