W203 C220 CDI OM646 POWER!
Old Jul 24, 2013 | 06:34 AM
KerryJ's Avatar
C220 CDI
HELP!!!!
I have a 2003 C220 CDI, with the OM646.963 from day one I was never happy with the power, and from my research it seemed the easiest way to make power would have been to sell it and buy something faster, but I didn't have to heart to do that, this was my first car, given to me at the tender age of 16, so now at this point, myself and the car share a rather significant bond.
I live in South Africa, so most specialized performance parts will have to be imported. The simplest solution to make a good power gain on this car of mine would have been to get the C320 CDI's engine and do a swap, but due to the unique way our services are rendered, I could not find anyone qualified to get it done. Doing it my self was a task I was not equipped for.
So I did the next best thing, I headed to Google, and found myself a Common Rail Chip (Race Chip Pro), plug and play. Had a local company(Xcede Performance) remap my ECU, stripped out the stock turbo and manifold and replaced it with the Turbo out the C320 CDI which proved to be a very large task, changed the Intercooler to a much larger one, and upgraded all the plumbing, from intake to exhaust.
I also fitted a 180HP Wet-Shot of Nos, but that’s only for when the need for extreme acceleration is needed.
My concerns are, I have fitted the bigger turbo, so I am making more boost, I would like to upgrade the injectors and camshafts to harness the boost properly, and maybe even the fuel pump to put more pressure on the line. But parts like these cannot be found here in South Africa, and tuning of Mercedes-Benz’s is very rare, so I have no idea what will be compatible.
I am also not happy with the performance of the OME Mercedes-Benz 320CDI Turbo I am using, but I know my ECU will not run without an Electrically controlled VNT Turbo, is there a way around this? Is there a standalone ECU I can use that will integrate with all the CAN systems in my car? Or simply default them?
I do apologize for my lack of technical knowledge, but I will sincerely appreciate any help, or knowledge shared. I want to get as much power out this little Diesel as possible.
Note* I have been running the car at 2Bar+ (My boost gauge stops there) under acceleration, and it stabilizes at 1.8Bar for the last 10 000KM’s and the engine has not skipped a beat…
Attached Thumbnails W203 C220 CDI OM646 POWER!-img_0126.jpg   W203 C220 CDI OM646 POWER!-pretoria-20120706-01919.jpg   W203 C220 CDI OM646 POWER!-pretoria-20120710-01990.jpg   W203 C220 CDI OM646 POWER!-pretoria-20120725-00076.jpg   W203 C220 CDI OM646 POWER!-pretoria-20120726-00088.jpg
Old Jul 24, 2013 | 03:39 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
220CDI and power aren't 2 terms I generally associate with each other.
I'd love to have the gas mileage though.
Have you gotten a dyno?
That would be interesting.
Old Jul 25, 2013 | 02:06 AM
KerryJ's Avatar
C220 CDI
I do have the dyno sheets from before the turbo and cooler upgrade, where I only did the Common Rail Chip, and the car made 147kW & 450+Nm on the Wheels, I will try and dig it up, but as for the new set up, I haven't taken it to the Dyno yet. I'm planing on changing the ECU so I can have more parameters to play with first, so when I do take it to the Dyno I can get it set up correctly aswell... Any management systems you would recommend that will integrate with out any above average modification needed to get it installed and working properly?
Old Aug 1, 2013 | 01:43 PM
isstay's Avatar
06 E320 CDI (GONE), 14 Jeep GC EcoDiesel, 01 Disco II (GONE), 09 BMW X3 3.0 Si Xdrive
Both of you, go ahead and read this thread, you will find many answers:
https://mbworld.org/forums/diesel-fo...0-cdi-mod.html
Old Jun 9, 2015 | 03:08 PM
onu777's Avatar
mercedes w203 c220 2005
hi guys can someone spue me what the problem may be, when I start the morning and press the accelerator up to 3000 starts to lose power, how it ends diesel and then recovers, it is EGR problem?
Old Aug 12, 2018 | 10:27 AM
Debilas123's Avatar
Mercedes-Benz C200 cdi 2006
probably an intake issue(?) engine not getting enough air
Old Feb 5, 2019 | 07:17 PM
Hernâni Campos's Avatar
c220cdi w203
MAP SENSOR
MAP Sensor problems
Old Oct 12, 2019 | 07:10 PM
Saulius Zeimys's Avatar
W211 E220cdi
How much power is possible on om646 110kw stock injectors ?
Old Oct 13, 2019 | 09:22 AM
c220cdi w203
Wat model engine hp you have?
Old Oct 15, 2019 | 04:22 PM
W211 E220cdi
I have e220cdi 150hp
Old Oct 16, 2019 | 06:15 AM
c220cdi w203
you can ho to 200hp easy
Old Oct 23, 2019 | 02:25 PM
W211 E220cdi
Is it hard to fit om648 turbo? what are the exact mods to do this? will I need to swap electronics from stock turbo on om648 turbo? or everything will fit bolt on ? will the car drive normally with om648 turbo or adjustiments with Star diagnostic needed ?
