The Instrument Cluster went dark after pressing reset millage
I stopped at the gas station, refueled the car, turned the car on, and pushed reset millage to zero. Then the instrument Cluster/display went dark. I was still able to drive car for 150 miles. Once I turned it off, I had to jump start the vehicle.
Those items are now off:
-AC/air volume control is off (not zero, but completely off- no chance to turn it on)
-windshield wipers do not work
-blinkers do not work
-power windows not going down/ not going up.
-power seats are off ( I actually unplug both seats because power seat module was draining battery last year)
-moon roof does not open.
-Radio/ CD works
-Lights work (when turned on, not on auto setting)
Any idea why this happened? I don't know if it is related but day before I used back window sunshade, and when it went down it made clicking sound. Is it possible that something is draining the battery. Car Battery is less than 1 year old. Alternator was checked before and I was told that is OK.
I would appreciate your answer or if you can point me the the link with more info. Thanks!
-Radio/ CD works
My guess is SAM module.
Maybe the press of a reset knob just happened to coincide with the display turning off.
I forgot to mention that now milles are stuck at 000 - the counter does not move. Speedometer does not move from zero. Gas level is on zero (but the tank was full) and RPM is on zero.
I also noticed that remote key did not open the car from the distance until I came to driver's door. I suspected the low battery.
but I would check voltages just to see where they are at as you had issues starting.
Rear sam is a very common issue though and I hope that you don't have to deal with that
https://mbworld.org/forums/c-class-w...repairing.html
samaritrey is correct in asking about the voltages.
Swift seems jealous of 1D's success as the likely billion dollar boy band. STFU comments at MTV/VMA awards etc.
"Hell has no fury like a woman scorned" seems appropriate after Harry Styles booted her for something better.
