exact oil level readout safe margins
Old Sep 1, 2013 | 10:27 PM
The Jury's Avatar
2002 c240
Hey guys,
What are the upper and lower limits and average amount of oil level I should see in the readout? I want to make sure I don't let it get too low and I don't want to overfill it if I ever need to add any.
Thanks!
Old Sep 2, 2013 | 09:36 AM
02C240's Avatar
c240
I know the proper level for the c240 is 8.5 qrts. How much driving have you done with only 5.8 qrts? did you get any "Add oil" messages?
Old Sep 2, 2013 | 10:25 AM
The Jury's Avatar
2002 c240
People please pay attention to the fact this is running oil level not what you added after a refill.
Old Sep 2, 2013 | 10:47 AM
Boom vang's Avatar
2019 C300 Wagon; '75 Triumph TR6; previous: 2004 C230 6spd sold after 17 years of driving
how do you get this readout?
Old Sep 2, 2013 | 11:15 AM
The Jury's Avatar
2002 c240
Dyno mode in the faq sticky.
Old Sep 2, 2013 | 11:48 AM
The Jury's Avatar
2002 c240
I must be the only one that actually reads the FAQs around here lol. Turn the key on first click press the reset button three times. It will only work within five seconds Of turning the key on and only if the mileage is what is displayed.
Old Sep 2, 2013 | 11:56 AM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
"Running" sump contents when it's not running.
Old Sep 2, 2013 | 04:05 PM
The Jury's Avatar
2002 c240
Thank you for the not running pic, I appreciate it. I am looking for a running M112 engine reading at it's "perfect" level if anyone has one please. Specific reason, thanks
Old Sep 2, 2013 | 06:46 PM
splinter's Avatar
Super Moderator
^ 8 quarts in the sump not running equates to ~7.2-7.4 running at a ~625-RPM temperature stabilized idle on mine.
It’ll vary of course contingent upon engine speed, windage, upstairs circulation, viscosity, drainback and chassis’ attitude/dynamics as the level around the sensor is also effected.
This can be graphically demonstrated by viewing the aforementioned readouts whilst underway.
All this with the same initial not running/not running quantity, e.g., 8 quarts.
Workshop safe margin method is to measure oil quantity, volume, and its resultant sump height up from the bottom of the pan via the extraction tube which eliminates several variables and all electronics from the equation entirely.
I have that information readily available in the archives, although those safe margin measurements are chassis and drivetrain specific.
Old Sep 2, 2013 | 07:12 PM
The Jury's Avatar
2002 c240
The reason I asked for running numbers is because contradictory to your information on mine these are the non running numbers which shows the engine circulating nearly 2 qts. Below are my off readings.
Old Sep 14, 2013 | 04:16 PM
jwil24's Avatar
2004 c240 4 matic
How do you get the first picture with measurements I only can get the second image.
Old Sep 16, 2013 | 08:18 PM
Khan28's Avatar
2012 C300 Sport 4MATIC (current) 2006 C280 Elegance 4MATIC (sold)
How do I get this on a refresh late model W203? I know the M272 motor has a dipstick and my oil currently reads at the middle dot which according the owner's manual is correct however I'd like to see what level it reads through the readout.
Old Sep 16, 2013 | 10:17 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
Should be like this:
key to first position, mileage on the display; press the reset knob three times, should hear a beep and battery voltage displayed on the screen, then scroll up (I think) to see the info with oil and stuff, then turn the ignition to ON (do not start).
