c320 intake options?
In all seriousness, no. This will never be beneficial to a M112 with the updated airbox.
There's no point in doing that modification. There's no power to be gained, and it's more dangerous. Stick to your stock airbox.
Not only that, but that engine cover will not fit in your car without proper modification. The rubber grommets which hold your original airbox are not in the right position to secure the cover to the top of the engine.
C32 people have done it. Would you be able to mimic what they've done? No idea if that would work or not, as unfortunately, I don't have either engine.
It's your money.
1. The filter is inside the engine bay, uncovered. Therefore it'll get hot and will just end up drawing hot air into the MAF.
2. The tubing is also uncovered, so if the filters won't draw hot air, the former will.
I mean it's your money dude, but it's not a good idea. Why make an aesthetic mod which pretty much only you (and/or your mechanic) will see, and that draws hot air into your cylinders? It's not worth it and I'd advise against it.
However, if you decide to make a CAI, use rubber, plastic, PVC, or metal tubing that's covered in thermal tape. You'd also have to find a way to cover your air filter the same way. Heck, I've seen people put filters inside of used coffee containers and it works pretty well. Unless you do it this way, you're not gaining anything, and even then it won't be any more efficient than stock.
Another thing that's not being discussed here is that the path of this type of setup is more efficient than dumping air from a tube into a retangular airbox, then pushed through tubing from there. I have no idea what this increase in airflow efficiency nets you, but I'd hazard that it's at least sumthin.
We can discuss this further over beers when I'm at our Mississauga offices next month.
I don't know the size exactly of the throttle body, but I reckon you could bolt an M113 throttle body right on. Airflow opened, potential for power gains. You could get a used throttle body for a decent price off ebay, and you could also find an M113 MAF housing for about 40-100 dollars, depending where you get it.
The Benz engines have well designed, non restrictive cold air intakes. There will be zero power gain.
If you want to mount a coloured tube plastic Jungle Jim under the hood for aesthetic reasons that is another matter.
Attachment 283052
too.
