Transmission acting funky
#: "140 990 46 01" or "003 990 02 12" or "002 990 53 03",,
Attachment 293225
ECStuning got them: http://www.ecstuning.com/ES1688417/ES1617053/
ZAYED,,
I found them at AutohausAZ, along with everything else I needed to do my transmission service.
However, after the service, I must say that not much has changed. We dropped the pan, changed the filter and drained the fluid 3 times. Fluid was brown originally and now much clearer and pink but it doesn't shift much better. It is still pretty harsh between 1>2, 2>3 is not as bad, but still noticeable. Downshift of 3>2 is a bit choppy at times, and 2>1 makes an odd "clunk" noise in the rear.
I have tried the trans adaptations reset, and I have cleaned the TCU and harness to no avail.
What else should I look for? Flex discs? Trans mount or differential mount?
The only thing the repairs I did fixed, was tighten up the shifting, and even that is still buggy.
I'm not sure where else to look for a solution.
