mercedes c230 1.8 kompressor cam sensor oil leak
mercedes c230 kompresser coupe
hi is there anyone out there that can help I have a Mercedes c230 1.8 Kompressor 2002 and I have been told to watch the cam shaft sensor as they leak and the oil goes through the wireing harness into the ecu but I have been told you can buy a extention cable for the sensor to stop the oil if it does leak but I need a part number for my Mercedes garage as they said its not on there system if anybody can help with the part number or tell me where I can purchase the cables in uk it would be a good help
Cheers
David
Cheers
David
https://mbworld.org/forums/c-class-w...-tsb-m271.html
Part number 271-050-27-33
http://www.rmeuropean.com/Part-Numbe..._5C1313F8.aspx
2019 C300 Wagon; '75 Triumph TR6; previous: 2004 C230 6spd sold after 17 years of driving
With the part number you should be able to find it, The part is made in the Czech Republic
http://www.oediscountparts.com/parts...&siteid=215242
You can call your dealer and ask them.
Boom Vang, I never told him to buy from the US seller
Don't you think that's kind of silly to do that?
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
Not silly unless that part is not available overseas. I may have to order the springs for my lock from the UK as seems that nobody sells it here so you never know
The recall was only in the US, even though this is a worldwide issue
