Before/After
Old Aug 7, 2014 | 12:09 PM
scottonfire's Avatar
2013 c250
Before/After
Before (9 months ago) look at this piece of crap
Before/After-vnbyev6.jpg
Since then here is what I have done
Vacuum Pump gaskets replaced $0
Camshaft solenoids replaced $100
Transmission mount replaced $30
Front rotors/brakes replaced $300 including labor
Oil Changed at 87.5K $50
Ambient temp. sensor replaced $15
Control arms replaced $350 including labor
Int. coolant therm. replaced $30
Back rotors/brakes replaced $130
Rotors painted $10
Alternator pulley replacement $55
Coolant Flush $25
Steering column manually locked $0
Power window cluster replaced $50
Int. door handles replaced $80
Leather gear shifter replaced $10
Steering wheel control buttons refurbished
Radio button repainted
Cup holder ring repainted
Tweeter cover replaced ($15)
Grille replaced $60
Front license plate bracket replaced $50
Windshield wipers replaced $40
Tail light bulbs replaced
Paint chips touched up $50
Fender liners replaced $50
Auxiliary input installed $50
Clear side markers $30
Chrome door handle inserts $20
Chrome mirror strips $10
Chrome lock pins $40
Chrome lic. plate holders $20
NOW LOOK!
Before/After-jgap2bm.jpg
Old Aug 7, 2014 | 12:28 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
Get some BiX headlights
After I installed clear side markers, my headlights started to look ugly and yellowish, so I was kind of forced to get BiX lol
Old Aug 7, 2014 | 12:34 PM
2013 c250
Originally Posted by VVF
Get some BiX
If my headlights get yellow, I'll just fade the side markers to match.
Old Oct 2, 2014 | 11:34 AM
castlev's Avatar
2K5C230SSMR
i know this thread is a couple months old, but i found a headlight restoration guy on craigslist. they sand down the top layer of oxidation and plastic, and make the headlights look almost new. cost me 20 bucks here in nj for both headlights to be done
Old Oct 2, 2014 | 12:17 PM
VVF's Avatar
VVF
Did he apply some protective coating after sanding? Otherwise it will cost you another $20 in a couple of months.
Old Oct 2, 2014 | 12:38 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
I used a Mother's kit that worked fine (the more deluxe version, where you do no sanding by hand - those work horribly).
Have done several pair now, so it's cheaper than $20 and took about 20-40 mins for each car. Much cheaper than bix.
Old Oct 2, 2014 | 01:50 PM
castlev's Avatar
2K5C230SSMR
yes he did, it was some sort of purple sealant. i forget what it was called.
Old Oct 2, 2014 | 08:40 PM
castlev's Avatar
2K5C230SSMR
Actually, I let him take a before/after, this was literally yesterday.
http://newjersey.craigslist.org/aos/4629559496.html
I can't believe he's using the photos already, I checked it out on a whim.
Old Nov 14, 2014 | 02:44 PM
Kneewall49's Avatar
C200 w204 wagon
Scottonfire, How did you 'paint' or retouch the black switch button'?
Old Nov 14, 2014 | 04:50 PM
Glyn M Ruck's Avatar
Super Moderator
See Cintoman's thread on healight resporation & UV protection
Old Nov 14, 2014 | 06:29 PM
2013 c250
If you're talking about the radio, I bought a thin paint brush, went to auto zone and got a black matte spray paint, sprayed the end of the paint brush, dabbed on to cover the white, then of course took back the spray paint since I only used 1/1000 of the bottle.
If you're talking about the buttons on the steering wheel, it's not paint, it's anti-paint. You can scratch off the soft streaky paint with your fingernail. Takes a minute, but looks so much better than peeling paint.
Old Nov 14, 2014 | 09:13 PM
Trey0702's Avatar
2014 E350 4Matic Coupe, 2010 E350 4Matic, 2007 C350 4Matic
Scottonfire, how did you get the trim ring painted on the cup holder?
Old Nov 14, 2014 | 09:35 PM
Kneewall49's Avatar
C200 w204 wagon
Ok thanks I'll experiment on one in the back so if it's a ****-up I won't be continually remindered.
