Repost of HID kit pic
Location: Houston,TX-moving to The Woodlands,TX SOON!!!
Toyota Tacoma & Lexus IS250
that's the entire KIT ????!!!!!!
geeeeez I think even I could handle that install !!!!!
only question is...where do those wires in the black protective covering attach ? assuming those plug directly in somewhere or do they have to be hardwired in to a power source or ?????
Are you talking about the plugs on the upper right? I think they attach to the plugs on the end of the wiring coming from the bulb. Then the long red and black wires attach to the stock plugs.
That's my guess, at least. Your results may vary. And if I'm wrong, I hope that someone here posts something saying that. I really need to crack open the hood and look around and see what the stock setup is really like.
ok yes that looks right.
now my question is....do the black and red wires plug directly in to an existing connector (power source)....like from the current headlamp power wires or are they non-compatible ?
Is the ballast small enough so it fits inside the dust covercap? That would be ideal.
When you install the HID kit, do you have to get the dealer to switch the setting from Halogen to HID before you install the kit. What would happen if you turn the lights on with the kit installed and the dealer didn't make that change. Does it not work, does it fry the ballast, does it work dimmer, do you blow a fuse?
2002 C230K
On the setting, I seem to recall someone posted that the lights will flicker on for about 15 seconds, then throw a fault. Not a big deal, but obviously the lights won't work until you get the setting changed.
