Exhaust smoke on start-up.
I live in New Zealand so the climate is very mild, I'll begin observing the exhaust on startup to see if I can get a clue but I'm still not sure what's causing it. It's not 'fluffy' and thick, it's wispy and definitely white. If there's any tinge of blue in it, it's not very obvious. It smells like regular exhaust except a bit stronger, like what you would get in a busy underground carpark. From inside the car, it looks like the smokes being pumped out for a few seconds then stops and quickly dissipates if I'm in the open, and it doesn't happen when I'm driving.
The computer hasn't whined about low coolant levels and upon visual inspection it's fine, despite not being topped up for quite a while. Nor has it been overheating, or running rough. The cluster also says the oil level is fine. I don't think it's the head gaskets since it's running smoothly and the smoke only appears on startup. I'm tempted to take it to a shop but could this just be condensation? (I'm not inclined to believe that since it's a recent phenomenon)
It sounds like steam to me. White and dissipates. Oil smoke is blue & contains particulates which will suck onto the back of the car. Overfueling is dark brown to black.
It might be normal.
What is coolant consumption?
What is typical oil consumption?
Does it clear on closed loop (non enriched) fully warmed up running?
It might be normal.
Coolant has stayed normal, I've only had to give it a small top up once this year.
In DYNO mode the oil level is showing 7.1L or 7.5 quarts, my last oil change was around 6000km ago and I haven't been really monitoring it. I'm going on a roadtrip tomorrow though and I'll see if there's any drop.
This sounds like normal steam from combustion at cold ctart to me. Just monitor it.
But steam would theoretically be odourless right? This stuff isn't.
The amount of smoke produced seems proportional to the amount of driving it's done, prior to being turned off and cooled down, e.g a hot restart won't produce smoke. And this is all happening in a New Zealand summer so it isn't exactly cold.
If I sit at a particular speed for a while i.e cruise at 80kph and then suddenly push it hard to 110kph then it belches out smoke, other than that everything is normal.
Coolant normal, will check oil level via console. I'm thinking it's something to do with the valve seals being worn, since the symptoms are pretty similar to what I'm getting now, I'll take it back to an indy or the dealer as soon as I get back home.
Another possibility. Are you loosing brake fluid? It should run out pretty quickly. There is a possibility you have a brake booster leak. Does not happen very often.
If you run the car down a hill against compression & then floor it do you get a cloud of smoke. If so it could be a sign of worn valve stem seals or rings.
Check coolant as advised. Watch oil consumption.
It feels like the oil sort of builds up as I drive and gets burnt off when the engine gets stressed, e.g after I makes lots of smoke then it's clear for quite a while.
The check engine light went on on the motorway, I believe for the first time in the car's history and it was accompanied soon after by very rough idling and seperately, a huge cloud of grayish/black smoke for a few seconds out the exhaust. The roughness went away when the car moved off and the new colour of smoke didn't persist, though the check engine light is still on. This is approximately a week after taking it to the dealer.
I'm taking it back to them, depending on what they say and how exorbitant the charges are gonna be, I'm taking it to a BMW & MB Indy nearby. I'm sick of continually having the car mis-diagnosed.
I'm still not sure since I'm not getting any constant smoking from the exhaust while driving, any smoke is a brief belch and only in conditions stated before. I can't say the 'misfire' is severe, I just went for a half hour city drive and all I got was the occasional slight vibration from the engine while idling (which has always been there AFAIK). I'm just surprised since it's a touch over 100,000 miles and the M112 is supposedly a very tough engine.
