good performance..... then bad again.
I recently replaced my upstream o2 sensor in my 2002 c230 kompressor coupe. I had a code pop up that said this was the problem, along with a map sensor and mass air flow sensor code. I had replaced my map sensor and my mass air flow sensor already so i know they weren't bad. I figured a bad o2 sensor was causing all this so i replaced it also. Now, the symptoms i was having was hesitation when first accelerating after a cold start and poor power and performance, almost like something was choking it. The first two days after i replaced my o2 sensor it hesitated once but none after that. I was so happy
. Then after two days the performance went way down and it started hesitating again.Codes popped up saying mass air flow and map sensor again! Mass air flow code is current code and map sensor code says pending, whatever that means. The exact problems I am having are these: Poor acceleration and slow 0-60 speeds. Also when i press the gas after stopping at a stop sign there's hesitation and a slight jerking followed by a surge of power when the gas finally kicks in. overall it just feels like my car can't breathe well!
I'm thinking it's a vacuum leak or a bad catalytic converter.If anyone has any advice or helpful information regarding these problems i'm having i would greatly appreciate it!
Also, on a side note, i only replaced my upstream o2 sensor and not the downstream o2 sensor, i don't think it's a problem but i thought i should mention it anyway. Thanks.
Anyways, I'm not an expert on your engine as I believe you have the M111 engine and I have the M271 but I would search on here and read as much as I can about all the threads people have posted on your engine on here. Trust me, you are not the first one experiencing this on your model year car. If you dig deep enough you will find a thread of someone with similar issues as you're now having and they eventually resolved the issue.
I don't know if you just purchased the car recently of if you've had it for a while but depending on mileage/age of the car I would start with making sure all recalls or "campaigns" for your car have been performed (Call the dealer and give them your VIN and as if there are any open campaigns on it) then go through the basics, new spark plugs and or wires if applicable, new OEM air filter, you already replaced the MAF and MAP sensors (hopefully with OEM ones), new fuel filter, new oil change with OEM oil filter and approved oil. There's always more you can do and I know it sounds like a lot but if you just recently acquired the car and you don't know the history on it, you can't trust that the previous owner or the dealer you got it from did things right so it is up to you to bring the car back up to speed. Good luck!
Condition of the spark plugs, gap, or have they been replaced recently, are they the proper heat range. Any whistle noises indicating a vacuum leak, try spraying some intake cleaner or brake cleaner around the various fittings on the intake to see if there is a RPM change, indicating also a vacuum leak.
Had you got previous codes for the mass flow and map, have you verified good electrical connections on both of these, try putting the old ones back in to see if there is indeed a difference, possibly wrong sensors installed (aftermarket)??
Keep us informed on any success, thanks
Good Luck with your efforts. Happy New Year
The mass air flow sensor I bought online from buyautoparts.com, it is their brand and it's made in China.
The map sensor is a Bosch and the upstream o2 sensor is a Bosch as well. the two codes i mentioned(p0101 and p0172) have popped up before.Here's something else interesting. My check engine light came on shortly before i bought my oxygen sensor. I was going to get an oxygen sensor anyway because I thought it would be good to have a new one. But this time the o2 sensor 1 bank 1 code actually popped up,( what # code it was i don't remember) along with the p0101 mass air flow code.
Anyway, I installed the oxygen sensor and drove it around some that night to break it in. The next morning, i take it to work and break out the diagnostic machine to clear the codes, and along with the 02 sensor 1 bank 1 code and the p0101 mass air flow sensor code there is two new codes!
the MAP sensor code and the p0172 too rich code.( Correction: I incorrectly labeled the MAP sensor code as p0172, that's the code for the fuel too rich, i forget what the MAP sensor code was, sorry!
) I know all this is pretty complicated and hopefully i'm not being too confusing! thanks for the help!
( and yes the advice about checking for leaks around the airbox is helpful, i will try it, thanks!)
i got new sway bar links and the sensor replaced as well as complete oil change spark plugs and fuel filter and air filters. this was all done by a mechanic specializing in Mercedes. the MAP sensor, o2 sensor, and mass air flow sensor i installed myself.
Sorry just re read your prev statement about the plugs however it would not hurt to pull the plugs and check the colour, are they the right plugs for the engine etc.
Sorry... had to clarify....
Also, at 175K miles you may also have other things affecting performance like dirty injectors, deposits on valves, etc. Good job on replacing the fuel filter, it would also be a good idea to buy a couple of bottles of Techron concentrate plus and pour them into your next two full tanks of fuel. A leaky injector could very well be responsible for that P0172 code and the Techron could eliminate that. Good luck!
I am of the mind if there are two ways to do it I always seem go the educating way, meaning I always learn from doing it the wrong way first.
Happy New Year
i feel so dumb for not noticing it. but yeah i also put a couple of bottles of techron through it. one was a fuel system cleaner ttreatment and another was a injector cleaner. i think they both helped.
