Another Widebody W203 Build
I've had her for about two years now; come a long way. Overall I'm happy with the way its shaping up.
Still considering:
- Changing the wing for something like a APR GT300
- Wider Wheels
- Going lower at the rear like an inch.
Whats it look like from the back? What are the little details you've added on the lower front bumper and on the front fenders? What size wheels/tires have you managed to fit w/ the fender flares?
We all have different tastes- IMO thats what makes modding fun.
Your car should be a reflection of you.
Regarding the wheels:
Widest I have ran so far are:
Front -19x9.5 with 235s
Rear-19x11s with 305s
I can easily do 10-11" in the front now, only concern is the tire rubbing against the spring because I'm running BC Coilovers.
The rear also has like 3inches extra of space.
I'm planning on going 3 piece 12,13" with like 325s, but lets see.
@danny2slick
Yup I will be posting more pics(have a TON). Just been alittle busy with work.
Its not exactly a kit, its just a bunch of custom parts I fabbed on top of the stock body.
@samaritrey
The car itself is a '02 C240. She came with AMG bumpers, and acouple of little other goodies like a small carbon wing, smoked corners.
The goal with it was to build it as much as possible while keeping it a reliable daily until I can just park it and then gut it and go full track car.
Here's what the back looks like:
Here's the Build
What she looked like the 1st day I got her
Then I started doing some basic stuff like blacking it out, smoked tails, dipped the wheels, etc.
Then got my first set of wheels (18x8 all around +32mm Offset
Then installed a 4" Wider body:
More to come later
-Let me know what you think, looking forward to hearing back!
First, the entire world knows it's a Mercedes. You don't have to write it on your windshield. You just look desperate to be proud of something. Like the honda folks.
Wing will slow your 0-60 times. It's for going around a bend more than 140kph. You do that often? You don't.
Springs on oem struts? They are already blown.
Stop messing with your body. These cars are put through wind tunnels and are designed for best results. YOU ARE RUINING EVERYTHING.
Please. Stop. Sell it. Buy a honda.
You did put the correct tire size on. I'll applaud you there. Lose the spacers.
To the OP, I appreciate all of the work as well, some I like, some I don't, but it's your car. I guess my question, though would be on eventually tracking it. A 240 is probably not the best platform to start from, unless you're planning a C32 or C55 swap; that I could see.
The point of the windshield decal was because:
1) I like the way it looks
2) makes it look more like a Mercedes track car which as I mentioned early has been my goal from the start.
Oh and I guess you didn't notice, the Mercedes decal was from the early build phases.
I have since change the decal to a custom decal I made.
Eitherway I understand if its not your taste though… Its cool by me.
Actually the car is on coilovers, guess you don’t know what those are…but no problem: they are basically fully adjustable struts that come with significantly higher springs rates and adjustable dampening so you can get the most out of your car for autocross/track day sessions.
And actually yes, me and a couple of friends do high speed runs nearly every weekend around the Bear Mountain area here in NY…so I do corner at over 140kph frequently. That’s why I invested in Coilovers, Adjustable Rear Camber arms dialed in at -3 degrees, 305 width Michelin Pilot Sport PS2s, and adjustable MBArts Toe Links.
I know you might not know half of what those things are (since you don’t know what coilovers are), so I’ll simplify it:
I made my suspension pretty much fully adjustable so it meets my long term goal of turning it into a track car.
Oh and that’s why I needed the spacers.
Not sure what you mean…I didn’t know your opinion mattered when it comes to my car
Lol, and what if I don’t? What are you going to do? Nothing.
Take it down a notch…its just a car, and my car at that.
If you don’t like it, just appreciate the work I put into it.
But maybe you can’t do that either because you have never built a car to this extent.
So I think its be better if you just ignore my thread all together
Haha yea absolutely a 240 is FAR from ideal, but it just kinda happened. I was in school when I started building it, and couldn’t really afford a second car so I just kept it and built it piece by piece.
And yes, I’d really like to do a C32 swap because I’ve seen several done successfully on here. That’s been my plan but haven’t fully decided yet
Also I still have a couple of parts on the shelf (specifically AMG Calipers) that I want in before I pull the trigger on the swap
ps - Where'd you get the LED tails from?
I actually have a pair sitting in my garage.
Heres the link to Tails
http://www.protuninglab.com/20mebecw2eus6.html
Quick snap from today: finally a nice day
Thanks man! Appreciate it!!
Grow up.
I’m sure you know what suspension geometry is.
Makes total sense considering you don’t know what coilovers are.
Definetly bro my car's a pos
That's my favorite response yet, coming from the guy who comes onto my thread and starts complaining about how my car doesn't match his taste. Nice job
