Is there Anway Around PROD on Audio10
1 Post
CLK Coupe 200 Komp 53 Plate
Hi ya, I have already searched and come up with a mixture of answer, i just got my audio 10 and its coming up prod, tried disconecting batery, pluging all connections back in but still the same problem.
Any idea's is it ****ed or is there a work around other than it going back to becker.
Neil
Neil
11' E-350 BlueTec
Is my understanding that the Audio 10 goes into PROD when the unit is turned on with no CANBUS/fiber optic cable attached to it. When I installed my Audio 10 (before Comand) it worked perfectly without any MB or Stardiagnose intervention. So I guess the solution will be to send the unit to Becker unless MB has some new functionallity added to the Stardiagnose to solve your problem.
Keep your fingers crossed !
'09 A4 S Line
Maybe this is a dumb question, but what is "PROD"? I only ask because I'm doing my Audio 10 install soon and want to avoid any potential problems.
'09 A4 S Line
Originally posted by Lynn
PROD means that the anti-theft feature has been enabled. The unit thinks it has been stolen and it will not function. Do not apply power to the unit until everything is connected.
1 Post
Ok my car's in at merc's having some warranty stuff done at the moment,
seat alarm
wing mirror prob's
wiper prob's
window noise
and tsb issue's
i have asked them to see if they can put auto fold on so when the key is removed or car is locked it auto folds the mirrors but htey said they'd have to check das for this setting but not sure, anyways i have check with my friend at merc's and he recons it can be done via das, as at present i have a audio10cc, which the car is set to and the audio10cd provides different info, even becker recons merc's can fix it, fingers crossed its going in saterday to try setting the radio up.
seat alarm
wing mirror prob's
wiper prob's
window noise
and tsb issue's
Originally posted by cliffybabe
I do have electric fold wing mirrors, so im hoping it can be done
1 Post
Update its the car that needs telling I have the audio10cd as the unit works fine in my dad's c class so its is a dealer trip. So im please that the radio aint ****ed, it was a good ebay buy @ £30 plus £12 p&p, which is about $80 bucks
Thanks for the advice
Neil
Neil
