Fuel Level Gauge not working after fuel pump and sender replacement
I know I correctly installed the pump and sender(and did not break the levelers!). The C320 drives nice.......I'm at a loss as what to do. I know I have about 4 gallons of gas(I pumped the gas out right before starting the work). I have not filled the tank(just the existing4 gallons) to see if that kick-starts the fuel gauge level.....I would hate to have to pull everything out with a full tank. The negative battery cable was disconnected during the work and reconnected at the end. Is there a step I am missing to get the fuel level gauge working again?!
Hopefully we can get some more experienced members to help us out.
Hope this helps
I replaced fuel pump and sender unit [as a preventive maintenance] about one and half year ago on my '07 C280. They worked fine for a year and the fuel gauge started to not show correct fuel level - after filling up the tank, for the first half [of tank] of usage, fuel gauge doesn't move at all (stays at full). Once half tank of fuel has been used up, the gauge starts to work and goes down to half mark when the tank is in fact empty.
I replaced the sender unit. Fuel gauge worked for couple of tanks of gas and went back to same problem.
