M271 New engine do i need new instrument cluster?
Old Sep 3, 2015 | 04:46 PM
zesarz4's Avatar
c230 2003 coupe 1.8l automatic
Question M271 New engine do i need new instrument cluster?
Hello , so i have c230 2003 coupe 177 miles with misfire cylinder 1
have been offered a c230 05 125 miles engine 800$
i have heard that the mileage is in the instrument cluster is that true? and so do i have to buy the instrument cluster of that car? and the cluster is different will there be a problem?
thanks!
first pic my instrument cluster
Attached Thumbnails M271 New engine do i need new instrument cluster?-mine.jpg   M271 New engine do i need new instrument cluster?-new.jpg
Old Sep 3, 2015 | 05:36 PM
EuroDriverSD's Avatar
2016 E350 Sport; Mom Wrecked the 2008 E350; sold the 2002 C320
I'm not sure whether the mileage is stored in the cluster or somewhere else in the vehicle's computer system. However, the odometer must be accurate as to the car itself - not the engine. Changing the mileage on the car is ILLEGAL unless you go do a bunch of paperwork with DMV to report that the mileage on the odometer is not the vehicle's actual mileage.
And yes, the cluster will be different. It will fit physically, but will not be compatible with your car's computer system.
Old Sep 3, 2015 | 05:41 PM
zesarz4's Avatar
Thank you !
Old Sep 5, 2015 | 06:54 AM
Dollos's Avatar
Mercedes C32
changing the mileage to the new engine will require the ecu, ezs, steering lock and cluster to be changed from the donor car as well, not just the cluster.
Old Sep 8, 2015 | 05:53 AM
gucci88's Avatar
280s w126, e240 w211 , c180k w203, e300 w212, 560sel w126
No you don't need to change the cluster. My 271 was recently flooded and I had to transplant the engine from a W204 C200. The shop just used star to program my old ecu to adapt to the higher displacement engine hence not requiring a replacement of the cluster nor the ECU.
Old Jun 22, 2016 | 10:44 AM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
Be careful with the higher mileage m271 engines. Timing chain stretch and cam sprocket wear problems. At least have them open the valve cover and inspect those items.
(Aaand he probably already done everything since it's a year-old thread)
Old Feb 8, 2017 | 10:00 AM
Cano Velez's Avatar
2007 CLS 550
Fuel injector #2 Misfire
Hello everyone 2007 cal 550 Engine light on and shows misfire fue imjectir#2. We replace it and same issue. We change spark plugs and coil and same issue
we swap between other fuel injector/ coils/ spark plugs and misfire 2 always comes up
the car runs great for 20 seconds and then starts hesitating.
any subjection ?
thanks
Old Feb 9, 2017 | 10:27 AM
Cano Velez's Avatar
2007 CLS 550
Anyone?
Old Jun 7, 2017 | 06:03 AM
nicochami's Avatar
c32 amg // ex rs4 b5
Es posible que tengas
Originally Posted by Cano Velez
Anyone?
es posible que tengas tapados los catalizadores.
Old Jun 8, 2017 | 12:52 PM
ODB's Avatar
ODB
2006 C55, 2024 GLC300 SUV
Вообще вот сейчас не понял, что ты написал
Old May 29, 2023 | 10:51 AM
Antonis_Antonop's Avatar
w203
Upgrade cluster!
Hello everybody! I have installed a 2006 cluster at my 2003 w203 but I haven’t activate the gps guide and auto pilot! Can someone help me? Also can I install a w209 cluster or a w211? They look nicer to me. Many thanks
