Question for people with upgraded brakes (spare tire)
ok, thanks... So I guess the only fix for this is to purchase a c32 or c230 spare tire?
Yeah a C32 wheel or C7 wheel from the C class will clear fine.
It should, because while the wheel goes up in diameter, the tire goes down in diameter; usually equalling out. If you know your tire size, I can tell you your overall tire diameter.
but i'm wondering if 17x7.5 (225/45R17) will fit since the width is wider than stock 16s...
If you have staggered set up, which wheel and tire width do you use for the spare ?
this is a repeat performance, but I see the frustrations so I'll chime in...
you only need the 'micro tire' that comes with the car. Unless you have some seriously large rear wheels that is...
if you get a flat on the front, simply jack up the rear, take one of the rear wheels off and replace with micro spare...
take rear wheel and replace the front.
yes it's an extra step, yes it's not perfect, but it avoids using foams and doesn't use up your trunk carying a spare.
Hope this helps!
<sigh>
Hope this helps!
I would like to do this idea, but my rear tire would never fit the front.
