Recommendations for new struts/balljoints (C270)
Old Feb 25, 2016 | 01:33 PM
SMP142's Avatar
2003 C270 CDi
Hello all,
I currently own a C270 and just the other day my front strut blew out and leaked oil all over my garage floor. I knew I was in need of new components a few months back, but I figured it may last until summer.
My question is whether or not my C270 has different struts and shocks than other W203 models? I know there were different spring rates and heights offered, but I just want to make sure I get the correct ones. It's an Avantgarde and rides pretty stiff. That may be due to the old suspension though. I know my front end weights more than others due to the 2.7 diesel. and thus I would think it uses a heavier duty strut.
I plan to source bilstein is the price isn't too outrageous, but does anyone use KYB?
Parts numbers would be great if anyone knows them.
I also plan to replace all of the front steering components as well. My ***** joints have a slight bit of play in them, so I am just going to to it all at once. Is there a particular brand to stay away from with these? I have seen many brand online, but am still new to the MB world.
Anything known to go bad in the rear?
Also forgot to mention I am in Italy, so I don't have access to a lot of MB parts around here. I may have to order online.
Any help is greatly appreciated. Thanks.
-Brian
Old Feb 28, 2016 | 05:42 AM
SMP142's Avatar
2003 C270 CDi
Also, how do I tell if I have the sport suspension? I read in another thread about having the 486 code on the card. Mine has it in teh first column, so am I right in assuming I have sport suspension?
Recommendations for new struts/balljoints (C270)-20160228_105201_zpsn28oze9r.jpg
Old Feb 28, 2016 | 12:43 PM
W203E35's Avatar
2006 C350 Sport 6MT
I replied to your PM but I just saw this. Looks like you have the sport suspension. I'll lookup the parts for you.
http://www.vindecoderz.com/EN/check-...2030161A409223
Old Feb 28, 2016 | 01:30 PM
SMP142's Avatar
2003 C270 CDi
Thanks a bunch. So it is really an 01? All my paperwork says 2003. That's Italy for ya. I ordered the control arms/steering kit, and the strut bearings. I guess all that is left are the struts and rear shocks.
Old Feb 28, 2016 | 07:51 PM
W203E35's Avatar
2006 C350 Sport 6MT
I got the numbers you need. Sorry on the late response. Make sure it has the 486 (sport) code. I have also attached images of all the part numbers.
Front Shock - 2033206630
rear Shock - 2033261700
Attached Thumbnails Recommendations for new struts/balljoints (C270)-c270.png   Recommendations for new struts/balljoints (C270)-c270_1.png   Recommendations for new struts/balljoints (C270)-c270_2.png   Recommendations for new struts/balljoints (C270)-c270_3.png
Old Feb 28, 2016 | 08:01 PM
W203E35's Avatar
2006 C350 Sport 6MT
Here are some PDF documents that might help. If you get stuck anywhere let us know. The arms aren't that tough. I also recommend changing the strut bushing. The top hat usually doesn't wear out but the bushing does. You will notice cracks at the top.
http://www.ebay.com/itm/2-REIN-Left-...xVQrML&vxp=mtr
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Feb 29, 2016 | 12:47 PM
SMP142's Avatar
2003 C270 CDi
Thanks for the help.
I found some Bilstein struts on ebay for $126. Sachs brand for $164. Rears are same brand and about the same price at $100 for a pair. Recommendations?
Also, is it worth doing the rear links while I am already replacing everything else?
Old Feb 29, 2016 | 02:17 PM
W203E35's Avatar
2006 C350 Sport 6MT
I went with Bilstein this time. There was a huge price difference between Sachs (OEM) and Bilstein. This is the first time I have used Bilstein but I'm sure it will be similar.
I'm just doing it all. The complete front arms/links and the complete rear arms/links. If you have never changed them might as well.
Attached Thumbnails Recommendations for new struts/balljoints (C270)-shocks.png
Old Mar 5, 2016 | 03:42 AM
SMP142's Avatar
2003 C270 CDi
Sorry, its been a busy week. Where did you get that price quote in the picture? I think I might as well order them.
Also, do these seem too cheap? Listed as a 210 number, but says it fits 203.
http://www.ebay.com/itm/8PCS-REAR-AX...-/261717334169
