W203 Black smoke, bad idle
Old Aug 1, 2016 | 02:27 PM
Karce12's Avatar
Mercedes-Benz C220 W203
Hello everyone, I am writing for Lithuania to your forum, because I do not really know what to do.
1)About couple months ago my MB w203 C220 CDI started dropping through exhaust a lot of black smokes, mostly of them on 700-3500Rpm's(kickdown). Maybe it could be an EGR valve or maybe something else? Where it is?
2)Another problem.. On the cold engine(idle), engine starts droping RPM's from 700 to about 500 RPM and it repeats about every 30-45 seconds.
Thanks a lot for answers!
Old Aug 2, 2016 | 08:45 AM
Karce12's Avatar
Originally Posted by Plutoe
Have you taken the time to determine any fault codes,if any??---If so post the codes!!
Hey, about a month ago my car was checked by diagnostic " Star " , at that moment, there were no any faults... But RPM's started dropping about two weeks ago..
Old Aug 2, 2016 | 09:21 AM
alecmascot's Avatar
W204 C220CDI 2011
Black smoke in a diesel is almost always insufficient air and is usually caused by a boost leak.
Check the ducting from the turbo to the intercooler to the intake manifold for leaks, and the intercooler itself.
rgds
Old Aug 3, 2016 | 10:42 AM
Karce12's Avatar
rgds
Today I was checking and i found this: it can cause black smokes?
Attached Thumbnails W203 Black smoke, bad idle-20160803_165230.jpg   W203 Black smoke, bad idle-20160803_163613.jpg
Old Aug 3, 2016 | 01:00 PM
alecmascot's Avatar
W204 C220CDI 2011
I am not sure where that is on your 220CDI, but if that duct is downstream from the turbo, then definitely.
rgds
Old Aug 3, 2016 | 02:14 PM
Karce12's Avatar
rgds
It is rubber which is one of two parts of air intake
Attached Thumbnails W203 Black smoke, bad idle-20160803_163613.jpg   W203 Black smoke, bad idle-ae983a56b03b.jpg
Old Aug 4, 2016 | 11:33 AM
alecmascot's Avatar
W204 C220CDI 2011
You could try a temporary repair with tape to see if it fixes the problem.
Old Aug 4, 2016 | 12:50 PM
finewayne's Avatar
C Class
couldn't agree more, best answer
Old Aug 6, 2016 | 03:45 PM
bibauporto's Avatar
C220 CDI W203006
I believe it could be that only if it is messing with the air to fuel mixture (with incorrect air flow values).
Old Aug 11, 2016 | 11:39 AM
Karce12's Avatar
Hey, I put some duct tape on that, ant it did not help me anyways... So i removed an EGR Valve and black smoke was mostly reduces so additional to this I put Chip Tuning. But anyways, bad idle on cold engine has the same problem, it do not make any changes... So any tips?
