M271 Timing marks off TDC
Old Feb 5, 2017 | 01:05 PM
hannajc111's Avatar
2003 C230 Kompressor
Hi all,
I was having a misfire on P4 and tried everything I saw on these sites to remedy it. Nothing worked, so I took the head off and had it resurfaced and a valve job too.
When I took the camshaft cover and shafts off, I set the harmonic balancer to TDC (0T). At that time I didn't check the piston to see it's position, but after taking the head off, all 4 pistons were at mid-stroke.
I'm reassembling everything and set the camshaft timing marks on the camshaft cover and camshaft adjusters so at TDC (0T), they match. Should be ok, right? I now find that when P1 is at the top of it's stroke, the marks are 45 degrees off, as seen in the picture. The harmonic balancer is also off 45 degrees. So I have no idea what the problem is.
I didn't mess with the crankshaft bolt while working on the engine, so I can't imagine anything slipped.
Can anyone give me an idea what is wrong, if anything? I appreciate any suggestions.
By the way, when the head shop took the valves off, the exhaust valve on P4 showed grooves in it, see picture and the piston heads had a lot of carbon buildup. I bought the used in 2011- it's a 2003.
Old Feb 5, 2017 | 01:52 PM
RedGray's Avatar
2005 C230K Sport Coupe
Before you took the head off, you should've set the engine at TDC with the balancer at zero, and made sure everything was aligned correctly.
The engine is a 4-stroke engine. So, the valve train doesn't have a 1-to-1 movement with the crank.
Set the balancer at zero. The first piston should be at TDC. Set the camshafts at their marks.
Also, I hope you cleaned those pistons. #1 and #2 are very nasty. That ******* will do bad things to the piston rings, the block cylinder walls, the valves, the cats, etc.
Good Luck!
Old Feb 5, 2017 | 01:56 PM
RedGray's Avatar
Oh yea, as an fyi, you must use new head bolts. The head bolts are torque to yield.
http://www.felpro-only.com/blog/prop...e-t-t-y-bolts/
http://www.acl.co.nz/wp-content/uplo...-Headbolts.pdf
Old Feb 5, 2017 | 02:28 PM
hannajc111's Avatar
Thanks for your reply RedGray. I understand what you've said, but what I did before starting any work was to set the crankshaft/balancer at 0T. When I took the head off, the pistons were at mid-stroke, as you saw in the picture with the dirty heads. That's the way the car was driving and I had no problems other than the misfire on P4.
Now when I turn the crankshaft, it moves fine, except when P1 gets to either the top or bottom of stroke and then I have to use a lot of force to continue turning it.
Yes, I did clean all four heads- took a lot of elbow grease, but they look like new now. I also did use new head bolts when reassembling.
Old Feb 5, 2017 | 03:27 PM
alecmascot's Avatar
W204 C220CDI 2011
There have been several instances posted on this forum where the timing scale on the crankshaft pulley has moved, just like yours. The solution is to buy a new one.
https://mbworld.org/forums/c-class-w...ings-help.html
Old Feb 5, 2017 | 04:02 PM
RedGray's Avatar
@alecmascot Thanks for finding that thread!
@hannajc111 That's what I thought you meant. But, I wanted to be sure.
As alecmascot posted, having balencers creep/move isn't anything new. It happens on many engines. It often happens after ~~20 years on many engines. It varies by engine, balencer, etc.
Old Feb 5, 2017 | 04:08 PM
hannajc111's Avatar
Ok, thanks for your reply alec. I'll move in that direction and realign everything.
Old Feb 5, 2017 | 04:21 PM
RedGray's Avatar
Hmm, I'm now going to have to decide if I want to replace the balencer on my car. It's often not an immediate critical failure. But, I don't want it to slip even a little bit, and then cause more stress on the POS timing chain.
FYI:
http://www.pelicanparts.com/More_Inf...VSVSI=3528.htm
Crankshaft Pulley
Corteco is an OEM supplier to Mercedes-Benz.
Part #: 271-030-00-03-M270
$201.50
OEM MB Crankshaft Pulley
Part #: 271-030-00-03-MBZ
$337.00
You can see where there is rubber between the inner and outer sections. That rubber going bad is what causes the outer section to slip.
Old Feb 5, 2017 | 04:30 PM
hannajc111's Avatar
Ahhh, ok, now I understand better. I was wondering how something with a key shaft could slip. Thanks for the clarification.
Old Feb 6, 2017 | 04:36 PM
alecmascot's Avatar
W204 C220CDI 2011
The fact that the outer part of the crank pulley has slipped, throwing off the timing scale makes no difference to the actual cam timing. The crank pulley just drives the ancillaries belt. You only reference the scale when checking the cam timing relative to the crank position. Any slippage on the pulley makes no difference to the operation of the engine.
Old Feb 6, 2017 | 11:14 PM
RedGray's Avatar
Nope.
Imho, anytime, someone sees something that costs more, weighs more, or is more complicated than simple/basic, they should ask WHY?
Also, the correct name of the part is a big clue - it's not "pulley" - it's "harmonic balancer".
Why would they make a two part "pulley" and put rubber in between?
The firmness of the rubber (durometer) and the outer section (mass) are there to reduce engine/crankshaft vibrations.
http://www.genuinemercedesparts.com/...per-2710300003
https://en.wikipedia.org/wiki/Harmonic_balancer
https://en.wikipedia.org/wiki/Shore_durometer
If/When the rubber starts to fail, then not only will the engine vibrations not be properly damped, also the incorrect damping of the harmonic balancer could lead to destructive resonances.
With the POS under-designed M271 timing chain, people are asking for the engine to turn into a "boat anchor" (only good for scrap) if they have a bad harmonic balancer.
What happens when mechanical oscillations are not properly damped:
Tacoma Narrows Bridge 1940
https://en.wikipedia.org/wiki/Tacoma_Narrows_Bridge_%
281940%29
From the time the deck was built, it began to move vertically in windy conditions ... Several measures aimed at stopping the motion were ineffective, and the bridge's main span finally collapsed ...
Neat Movie of the bridge oscillations and then collapsing:
https://upload.wikimedia.org/wikiped...estruction.ogv
Btw, a quick talk about the above bridge, along with showing the movie, is done in just about every Freshman year for Mechanical Engineering students and most Engineering students.
Old Feb 9, 2017 | 08:31 AM
hannajc111's Avatar
Thanks for the very interesting lesson. I'm replacing the harmonic balancer, so I should be good to go. It seems like they could come up with a better solution than something that is so important to the operation of the engine and yet is a common problem.
Old Feb 12, 2017 | 06:17 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
RedGrey, thanks for posting. For balancing purposes I always thought of crankcase flex as a result of horizontal/vertical displacement, but never thought of harmonics from a torsional standpoint. Learned something new. Always thought it was strange why they would use something "weak" like a rubber ring on that harmonic balancer. This explains a lot.
The Tacoma Narrows video is classic. Definitely remember seeing it in high school physics class.
