Very odd electrical issue please help!
Old 03-10-2017, 09:18 AM
ninjaff21's Avatar
2012 Genesis Sedan, Whatever Benz i have at the time
SOLVED: All electronics dead when engine running
Solved: New battery, key, fuses, and cleaning the SAM solved all of my issues.
ihave a 2002 Mercedes C240.
UPDATE: cooling fan stays on full blast anything past startup!!! i now have code P0600 its the only code i can clear it and read it but it comes right back. I'm going to assume that means the ECU is not fried and is communicating. how i wish i had a star.
Update: SRS LIGHT IS ON!!!!!!!!!
so I get In the car put the key in and it unlocks steering. Turn to position 1 steering wheel comes down and seat moves forwards. I have control of the center menus at this point and seat control. Turn to position 2 all dash lights come on all electronics work, and a weird constant loud tapping comes from the center behind the radio. Turn key to start car starts right up and drives like no issues. BUT the steering wheel goes up the seat goes back all electronics turn off and the radio little red led flashes and the coolant fan will occasionally go full speed.
Steps i I have taken so far:
Searched for hours found a simmilar issue but they were having no start no run bad ecu. My car runs and drives very smooth.
I replaced the crappy salavge yard battery the PO had in it with a proper H8 group 49 battery.
can someone please explain what the heck is going on and what I should check next? I'm rather mechanically inclined but this is so bizarre to me. I was thinking it's the ICM but the key locks unlocks car, the steering wheel, and starts it just fine.
Please help!!
Old 03-10-2017, 10:59 AM
Plutoe's Avatar
Received 1,021 Likes on 949 Posts
1999 E300TD
post your VIN!
Old 03-10-2017, 11:02 AM
ninjaff21's Avatar
my vin is WDBRF61J12F191183
being everything works with the motor off I'm not sure what could be the issue. its literally as if when you turn the motor on you turn the car off. never have had an issue like this before
Update: the stepper motors are all working in test mode it seems like one is clicking though. i can't use the controls to control the vents though it seems to be stuck on the floor.
Update 2: the vehicle was most likely jumpstarted with they key in the ignition last night. i am a used dealer bought the car at auction most of them are flat batteries. not sure if it was jump started or not.
Update 3: key is now hit or miss if it will actually turn in the ignition or not.
Old 03-10-2017, 11:31 AM
ninjaff21's Avatar
Update 4: i just looked at all the fuses in the trunk and the dash panel no fuses are blown.
Old 03-10-2017, 07:36 PM
Plutoe's Avatar
1999 E300TD
In three posts you have eluded to many issues on your car.
Maybe after a good nights sleep you can review the posts and list the most pressing issue then we can all move on to a solution.
Old 03-10-2017, 08:42 PM
ninjaff21's Avatar
The biggest issue is when the engine is running the electronics all electronics do not work.
Old 03-10-2017, 10:56 PM
SunnyRayToronto's Avatar
2003 C230 Sports Coupe, Paprika Metallic Red, Auto, Pano, Leather
Code P0600 is communication failure code - a computer (like ECU, TCU, EIS, etc,...) could have failed or gave BS signal or something - check all grounds to ensure they're good and check wiring for any damage. Ensure main wiring harness at ECU isn't soaked in oil! Any sign of oil leaking anywhere in engine bay?
When computer fail or communication fail, modules don't get their expected signals or any signal at all. IE: Front radiator fan control module don't get signal so it automatically goes into high turbine mode like a jet engine - that's it's default safety state! It does that incase if the engine's on fire or overheating - to protect the engine.
Clear P0600 code and restart. Try to get a different code!
Old 03-10-2017, 10:58 PM
ninjaff21's Avatar
Tried resetting code didn't do anything. All wires seem fine. I'll check for oil but I don't see oil really anywhere
Old 03-10-2017, 11:17 PM
You put in a OEM Mercedes-Benz battery, right?
If you're very good at diagnosing electricals, you could access CAN-BUS wiring under driver's front door sills near front and tinker there to try to figure which signal is missing,.... otherwise, it's best to leave that to a pro!
Old 03-11-2017, 12:16 AM
ninjaff21's Avatar
No I used a group 49 from the parts store
Old 03-11-2017, 12:41 AM
Mercedes are really fussy about battery. Only use OEM Mercedes-Benz car battery! Aftermarket battery are usually underpowered - not enough Amps - need 100Ah.
That said, it's possible but not likely for an aftermarket battery to somehow affect one of the computers which would trigger a P0600. It's better to just drop in a OEM Mercedes Battery and start diagnosing from there. Electrical stuff are a pain to diagnose and something like an aftermarket battery won't help.
Speaking of aftermarket, does the car have any other aftermarket (non-stock) electrical add ons,.... like aftermarket HID lighting, stereo, etc,... something where the wiring is questionable,...
Old 03-11-2017, 01:29 AM
ninjaff21's Avatar
Nothing aftermarket. I will get a Mercedes battery on Monday
Old 03-11-2017, 10:33 AM
When installing the new OEM Mercedes-Benz car battery - do follow the procedures in the manual perfectly, otherwise it's very easy to damage the Front-SAM.
Old 03-11-2017, 11:19 AM
ninjaff21's Avatar
Do these symptoms sound like a bad Sam to begin with? I feel like the auction jumpstarted it wrong or the people before just kinda messed it up with their to small junk yard battery?
Old 03-11-2017, 11:57 AM
ninjaff21's Avatar
I would like to add that when the engine is running brake lights work headlights can be controlled and tail lights work but signals do not. Those are the only controllable working electronics when the engine is running and I can turn the radio on. Like I said it just like if the car is off. I believe I can open the trunk also.
Old 03-11-2017, 01:02 PM
Did this car ever work properly for you? Or did you buy it at auction as it is now?
With electrical issues, you want to get the car back to stock or as close as possible,.... that includes new OEM Mercedes-Benz battery. Regardless, that's the battery you need in this car. Once that's done, we'll know you have the proper battery with real juice in it and then we can start figuring things out.
After that you want to hook it up to a real code scanner (ideally MB Star DAS) but at least something that'll give you a real log of what's going on when you try to start. Right now, you're only getting P0600 Communication Failure - which is the latest error code after the car gives up, but what is triggering it! You need something that'll read a log!
Old 03-11-2017, 01:52 PM
ninjaff21's Avatar
Yes it worked properly on my test drive. Then after I brought it back said all was good and paid I went out it started right up no issue but the issue instantly happened then. When it was in the parking lot I could turn the key and it not start but electronics worked I assume dead battery and the auction jumped it.
Old 03-11-2017, 06:08 PM
How does Signal not work? Both left and right don't work? And both front and rear don't work? If so, that could be a signal switch issue. Which is relatively common problem.
Did they work during test drive?
Old 03-11-2017, 06:21 PM
ninjaff21's Avatar
Yes when the electrical failure is active only headlights tail lights brake lights work no other electricals
Old 03-12-2017, 04:40 PM
ninjaff21's Avatar
Update key will no longer turn in the ignition steering column remains unlocked. I suspect my key has died or it's the ignition.
Old 03-12-2017, 11:09 PM
ninjaff21's Avatar
Bump:
i took key apart things were rattling around inside. Key is bad I assume. Getting a new key ordered tomorrow. could the key be causing all of this?
Old 03-12-2017, 11:36 PM
tell us what happens AFTER you put in a new OEM Mercedes-Benz car battery
Old 03-13-2017, 03:18 PM
ninjaff21's Avatar
ordered a new key and picked up a mercedes battery. battery changed nothing. looking at the front SAM i pulled a few fuses and they were very burnt/corroded. I'm going to pull the front SAM and clean it with contact cleaner. Maybe replace the fuses. With the ignition off fuses 43-52 do not have power. also when looking at the diagram my car has a relay that isn't on the diagram???? i attached a picture to this post. there is the 2 relays with the 3 under it. mine has 3 with 3 under it.
Old 03-13-2017, 03:50 PM
Good, now that you have the proper OEM Mercedes-Benz battery installed, we can eliminate that as a problem.
I assume, you never got a second key? In which case, ordering a 2nd is always a good idea.
Why are some of the fuses in the Front SAM appear corroded or burnt? Was this a flood car? Or blocked water holes near Front SAM area and battery compartment causing corrosion issues?
I wouldn't worry too much about the "extra" relay. Some cars have them, depends on which options and trim level you have.
After you get FrontSAM cleaned up. If it still does not work, then start testing relay. Here's how I "test" relay. Not ideal but easy! Uniquely number relay and up direction then with KEY OUT! - switch similar sized & colour relays around (FrontSAM and rearSAM if needed). Then try to start, if it doesn't work then with KEY OUT, switch them back and try another pair,....
https://mbworld.org/forums/c-class-w...ml#post5202308
You still need a to read code.
Old 03-13-2017, 04:14 PM
ninjaff21's Avatar
Ok to update you more on the SAM i have pictures I'm going to upload. IT CLEARLY HAS JUNK YARD MARKINGS!!!!! I'm going to try cleaning it and testing relays like you have said. Could this all be caused by the not so bright previous owner not coding in the junk yard SAM? if you saw the dealers i bought it from at auction you would assume they had no idea about the car. An uncoded or bad junk yard sam would explain a lot of this in my opinion. also most junk yards leave hoods open ETC. which could allow for water to get in explain all the corrosion.
While removing the sam i also removed the ECU. as i hear a blown ecu will have rattling. the ecu does not rattle but has a small dent in it.
CORRECT ME IF IM WRONG: the sam in my car is part number 209 545 00 01
pelican parts says the correct part number for my c240 is 203 906 00 05
if I'm correct the sam i have here in my hands is for a CLK (w209) not a c class (w203) like i said correct me if I'm wrong. but from what it looks like my car has the completely wrong part number currently in it!
Quick Reply: Very odd electrical issue please help!
