W203 c240 auto transmtion problem
Old Jul 7, 2017 | 01:35 PM
Thabovuyo's Avatar
W203 c240
Yesterday i was cleaning my car inside and by mistake the water went inside the gear selector, now the car is driving in one gear and gears change hard. Please help
Old Jul 7, 2017 | 01:37 PM
OneAdam12's Avatar
2006 C230 Sport
How much water are we talking about?
Old Jul 7, 2017 | 01:42 PM
Thabovuyo's Avatar
W203 c240
Less than 5ml, i think the water went inside the w/s button
Old Jul 7, 2017 | 01:56 PM
OneAdam12's Avatar
2006 C230 Sport
Do a youtube search for "w203 Shifter Shifting Knob Removal". You can remove the trim and c/s switch around the shifter. Be careful not to break the clips. You can then try "drying" the switch out, and you'll be able to see if there is any water in the opening beneath it. Leave it disassembled to allow as much water as possible to evaporate. I'm not sure what else is in there that the water could have damaged, someone else on here will probably know though.
Old Jul 7, 2017 | 02:02 PM
Thabovuyo's Avatar
W203 c240
Thank you
I will do that
Old Jul 10, 2017 | 11:26 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W203 forum...
Old Jul 10, 2017 | 06:05 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Otherwise you will need a new shifter. $700 US.
Sensor not available by itself.
I managed to get one from a junkyard.
MJ50, where'd you get the Stig's Helmet?
Old Jul 11, 2017 | 01:03 AM
Thabovuyo's Avatar
W203 c240
The car is still having a problem of not upshifting, only drives in 1st gear.
Yesterday i took the car for diagnostic and it shows TCU low voltage and speed sensor error.
Does anyone have an idea what needs to be replaced?
Old Jul 11, 2017 | 11:35 AM
tjts1's Avatar
C320
Your transmission has locked itself in limp home mode. You need to have what ever damage was done to the shifter repaired and the TCU reset.
