Intermittent Door Locks
My 2002 C320 (203) has intermittent issues with the locks. I can only lock all the doors manually from the button inside. Can also open them this way. Trunk lock also works from inside.
But with the remote I can SOMETIMES open the trunk and the 3 doors but NOT the driver door. Have to manually lock from inside and use the key to get back in.
Checked all the relevant fuses and changed the battery in the remote. Still no luck.
Any help would be greatly appreciated and whoever provides the solution will receive an 2018 AMG Black (your choice of model).
Subject to:
1-Your solution fixes the problem.
2-I win the next Powerball lottery.
This is the second time you have responded to one of my posts with useless information. Do you even read the questions?
This time you suggested I change the battery in the fob. My post says I did all that as well as checking all the fuses.
My last post was about wipers not working. You suggested that I either throw parts at it until they work, take it to a mechanic, or buy a bunch of test equipment.
You need to get a life because all you do is waste time and effort with inane replies that are of no help whatsoever
Get a pen pal or something
Why do you spend the time to give non-information?
The answers you give are of absolutely no value. Stupid comments consist of ridiculously general insights that are so obvious they don't warrant any consideration.
Question: My car won't start.
Your brilliant insights : Do you have gas?
Is the battery dead? Did you try using the ignition key? Did you turn it all the way to the right? Are you in the car? Is it your car?
Please don't reply to me ever again.
Thank you very much for the tip. Just one question: Where is this module located and what does it look like? Also, is it necessary to disconnect the battery?
Thank you Thank you Thank you!!!!
The bad news is that the locks don't work again. Went to the deal to pic up some new SAMS for my wipe issue (they didn't help either). But the parts guy mentioned key fob being the issue. I told him I put a new battery in and he said that sometimes the run of the mill batteries don't work, and replacing it with one from MB fixed the problem on occasion. He gave me a brand new one but it still doesn't work.
Hope you have some more tips to getting a new 63.
