AC Compressor Clutch Bearing replacement
... at a cost of $20-30 vs $400-500 for replacing the entire compressor and dealing with the refrigerant evacuation and recharge.
Also, there is a Mercedes technical service bulletin stating that you can replace the clutch bearing without removing the compressor from the vehicle.
However, I am having a hard time finding the specific bearing to purchase.
Here is a pic of the label off my compressor:
Showing it as a Denso model 7SEU10c, Denso part #447180-9712.
Based on this guide -- https://www.carid.com/images/denso/a...ts-catalog.pdf -- The current Denso model for our M271 engines seems to be #471-1580.
However I am having a very hard time finding info on what bearing to purchase. There are at least a few different sized bearings sold for Denso AC compressors. I am, however, able to find the complete pulley/clutch assembly for sale, part #0002341412 ... but it's ~$200.
Has anyone replaced just the clutch pulley bearing on their Denso compressor?
Can you provide me with any help in locating the correct bearing?
Thanks. John
** UPDATE ** I was able to find results when searching for clutch pulleys ... found some online that specify the bearing as 35x52x22mm. I also noticed from the pics that the bearing seems to be held into the pulley channel by little divots stamped into the ring surrounding the bearing. I wonder if it will be possible to remove the bearing from the pulley without destroying the pulley (which appears to be made of plastic.). Pulleys seem to be readily available on eBay from a German manufacturer (TTK) for $50-70. I couldn't find much info on TTK so don't know if that is a reliable brand ... I did send them an email to ask where they source their bearings from ... they said C&U and Taide, both Chinese bearing companies.
https://www.mbpartsworld.com/
Personally I would rather replace the entire compressor as the car is 13 years old now and I'd like to get all of the front accessories replaced with new ... but as I haven't been using the car much I've been putting this off ...
-- John
I pulled the belt and the and it just about fell apart
Fyi these cars are over 10 years old now ... if you plan to keep the car long term I suggest eventually replacing all accessories on the car, including kompressor.
The compressor itself cools fine the noise goes away when comp runs
Bypass belt:
Duralast 910K6" or 6PK2310
