Location of Antenna Amplifier in W203 Wagon?
Old Apr 27, 2018 | 04:32 AM
bobinyelm's Avatar
C320, SLK230, T1N Sprinter
2002 C320 Wagon
I am trying to fix a non-working RF Central Locking issue that just started.
(Infrared function works perfectly)
I understand that the RF portion uses the same antenna amplifier the radio uses.
My AM radio reception is VERY weak, though frankly I am not sure I ever tried AM before.
My Rear SAM Fuse #8 that I am told powers the antenna amp is good.
The wagon has printed antennas on both rear side windows, and I do not know where the antenna leads are routed from those windows.
Anyone know where the antenna amplifier is located on the wagon?
FWIW I found a box type amp not looking like the type attached to glass showing it came from a wagon, but not WHERE in the vehicle:
Thanks,
Bob
Old Apr 27, 2018 | 10:01 AM
RWDlifer's Avatar
2005 C230K SS
On the sedan and coupe it's on the top edge of the back window...try feeling behind the headliner edge.
Old Apr 27, 2018 | 01:58 PM
bobinyelm's Avatar
Yes, but because the wagon has TWO antennas, and the hatch w/ the window opens, I was thinking maybe it would probably be a different location.
Plus the photo of the alleged amp for the wagon doesn't look anything like the photo of the one shown for sedans.
Just trying to pin it down before I destroy my car's trim.
This is the type I think the sedan has: https://www.screencast.com/t/37JTE1qrE2
This is the type someone said came out of a wagon: https://www.screencast.com/t/Q9DYwP5e
I am clueless at this point personally.
I am pretty sure my OEM radio should work better on AM than it does, so maybe the amp is out if AM and Central Locking use the same amp.
FM reception is GREAT, though.
Bob
Old Apr 27, 2018 | 06:54 PM
structure's Avatar
2002 MB CLK320
Bob,
I'm not sure if this helps but here's a link for the antenna/amplifiers in your c320 wagon: https://www.ilcats.ru/mercedes/?func...45&language=en
Old Apr 27, 2018 | 10:15 PM
structure's Avatar
2002 MB CLK320
Bob,
Here's some more info on the antenna amplifiers (Click on the Page 13191, Page 13192, Page 13193, Page 13194 links on the left for more pages on this topic): https://workshop-manuals.com/mercede...creen_antenna/
Old Apr 28, 2018 | 12:42 AM
bobinyelm's Avatar
WOW!!
Those are a LOT of Antennas and Amplifiers!
I see that many are for other markets. I appear to have antennas in both side windows, and of course, there is a tiny rubber-ducky antenna on the back hatch glass I assumed was for the built in cell phone installation.
Not sure which is which and for what, unfortunately, but I will study the linked diagram to see what can learn, however.
Thanks,
Bob
Old Feb 10, 2020 | 11:05 PM
houseofbugs's Avatar
2005 E500 Wagon
deleted.
Old Jul 6, 2021 | 03:09 AM
Golferjay's Avatar
W211
W203 2001 saloon
I know this is an old thread but my fm and am radio reception is really bad in that i can only pick up a few channels, my key fob is fine and central looking works as it should.
im try to locate the antenna amplifier to see if it’s causing the problem, does any body know where it’s hidden?
many thanks
Old Nov 1, 2021 | 06:44 AM
starship001's Avatar
C220 cdi auto estate S204
FM?M Radio signal poor
many thanks
Same problem here - everything okay except FM and AM radio signal very poor. I tried fitting a 'universal' after market antenna which works fine until key position 2 when there's loads of interference. As I can't fix the new antenna properly, I'm wondering if it is the amplifier - but which one, and where is it??
Thanks in advance.
2008 E220 CDi estate W211 with Audio 20 head unit
