Balance Shaft Failure
I think I may finally be plagued by the dreaded balance shaft sprocket failure. That said, how would I know for sure? At present, the car will crank but the idle is ridiculously rough, the gas pedal is unresponsive, and will not idle for more than a few seconds. My scan tool is giving me the following codes:
P0016 - Cam Sensor Position
P0017 - Cam Sensor Position
P0018 - Cam Sensor Position
P0300 - Misfire
P0304 - Misfire
P0305 - Misfire
P0306 - Misfire
P0366 - Camshaft Sensor Signal Implausible
P0391 - Camshaft Sensor Signal Implausible
This is an 07 C230 with approx. 180K miles. I previously had codes P0016 and P0017 along with the P2006 for the intake runner. Am I dead in the water at this point? My guess is the P0366 and P0391 are residual and changing just the cam magnets will do absolutely no good at this point.
Any advice is appreciated. I'm honestly at the end of my rope here.
You need the datacard with the engine number, big thread on this in the W164 forum on benzworld,
someone can check for you.
180K, almost guaranteed if you're in the range.
Worn teeth lead to loose chain...
We just had this repaired after finally finding a mechanic competant enough to do it on
our 06 ML350 @ 170K miles. No it wasn't cheap, but it also had a ton of other things wrong
and we got them all fixed at once. Like a new car again.
Crank pulley and TDC. This is the point where the stamp on the cam is visible through the Hall effect sensor hole on the timing chain cover. This should be at or around 305 degrees, which it clearly isn't. It's off by nearly 65 degrees.
After further review, I was able to determine that the telltale stamp is visible right around 240 degrees....nowhere near 305 like it is supposed to be. I had hoped that this would be something simple like a bad batch of gas, fuel pump going out (I say this because the motor was unresponsive to the gas pedal), or something of a similar ilk. Had even considered the possibility of a clogged catalytic convertor, vacuum leak, or an issue with the intake manifold.
My motor is confirmed to be in the affected range according to the datacard. Seems like I've got all the evidence I need to declare this a loss.
A very sad reality this morning. I need a drink...
We finally found a guy here in San Jose who's competent on this.
And I know a guy in NJ as well.
Guy in San Jose, (former dealer mechanic) would be about 3-4 grand including the new intake manifold which it sounds
like you'd need. Sounds like a lot, but it's be perfect when you get it back.
Guy in Jersey does them on the side, and might be less.
Ours ran like crap except when you had your foot into it.
We also had a blown intake manifold.
All fixed now, runs very quiet and smooth...oddly though, with a little less
giddyup.
Does this knowledge change your opinion of my issues any? Or am I still looking at heads, intake manifold, and balance shaft? If so, then this is simply too costly a repair to justify keeping the vehicle.
