W203 C-Class tech bulletins
Rating: Thread Rating: 9 votes, 4.89 average.
Old 03-22-2004, 02:32 AM
  #76
levelr123g's Avatar
for some reason i cant post it. if somebody wants it email me and i will send it to them, maybe you can post it.
Old 03-22-2004, 02:22 PM
  #77
paul-the-limey's Avatar
2001 C240 Elegance Auto Lthr
Hi, Could you mail it to me as per my PM to you please. If you could use the paulsmith.mail address that would be great.
Paul
Old 03-22-2004, 02:46 PM
  #78
vadim's Avatar
'19 GLC 300, '19 TM3SR+
Originally posted by nov0798
here is a tech bulletin that mb gave me a link to. I verified that my car was drifting to lean during accel, by storing the data on my laptop when i made a full thrttle run. when i went to the dealer, the pompus *** tech said " how do YOU know your car is going lean, YOU dont have the software to measure this" so i wipped out my laptop, and showed him the run with all the other data on the car. needless to say they flashed the rom and the car pulls much harder now. here it is. oh yes it took them like 20 minutes to flash it.
What software did you use to acquire the data? Thanks!
Old 03-22-2004, 02:48 PM
  #79
vadim's Avatar
Some .pdf documents do let you select text, others don't. Yours is probably the case of the latter. You may need a program called Adobe Distiller to do the extraction; otherwise printing, scanning and posting as an image would be the only way.
Old 03-22-2004, 04:17 PM
  #80
levelr123g's Avatar
here is the software i use.
http://obd2.com/
Old 03-22-2004, 06:45 PM
  #81
BruNo's Avatar
07' ML350
whos got a complete TSB on C240s??????
Old 03-22-2004, 10:42 PM
  #82
Geoff's Avatar
Send it to c_v at email dot com and I should be able to find a place to host it.
Old 03-23-2004, 12:29 AM
  #83
levelr123g's Avatar
ok i sent it to the email
Old 03-23-2004, 08:23 AM
  #84
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
Since I had the rough idle TSB done I now experience hard starting conditions after the car sits for ~ 8 hrs. I noticed on the list that there was an issue with this after a fuel filter replacement. The dealer did not replace the fuel filter. But could these 2 issues be somehow related?
Old 03-23-2004, 09:34 AM
  #85
hi there nov0798. I didn't get the mail from you with the TSB. Can you mail it to paulsmith.mail at ukonline.co.uk please.
Thanks.
Old 03-23-2004, 06:34 PM
  #86
BruNo's Avatar
07' ML350
do u guys have TSBs for W203 sedans???? pls email me at bruno787@yahoo.com
i have this rough idle problem my dealer cannot fix. my engine pulley has eaten my serpentine belt too....
thanks.
Old 03-23-2004, 06:37 PM
  #87
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
Please read this thread as the TSB #s have been posted.
Old 03-24-2004, 11:03 AM
  #88
Hi there,
Still no sign of the email nov0798. Have you sent it to me? My warranty runs out in 2 days so I would really appreciate it.
Paul
Old 03-24-2004, 01:37 PM
  #89
levelr123g's Avatar
sorry, didnt send it. I got caught up last night in a mass arrest at work and was here for 13 hours. ill try to remember to send it tonight.
Old 03-24-2004, 09:27 PM
  #90
champa's Avatar
e500 4matic; c240
Re: Water in gas?
I am no chemist but I believe water vapor is a byproduct of combustion, so condensation in the exhaust would be normal.
Originally posted by mleskovar
Rough idle and lack of throttle response are indicators of water in gas/petrol. Is there moisture coming out of your exhaust pipe? Drips of water from the pipe at idle are a good indication or just hold your hand close to the exhaust and see if there's moisture condensing on it.
Old 03-24-2004, 11:05 PM
  #91
levelr123g's Avatar
just because there is water coming out of the exhaust does NOT mean that there is water in the gas.
Old 03-25-2004, 09:41 AM
  #92
champa's Avatar
e500 4matic; c240
my point exactly....
Old 03-25-2004, 11:23 AM
  #93
Hi, Here is the TSB as a jpg image. Thanks to NOV0798 for sending it to me. Unfortunately it is only for 2002 and newer W203's and mine is a 2001 model. Damn!!
Old 03-25-2004, 12:52 PM
  #94
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
You need this TSB S-B-07.61\27A as well
Old 03-25-2004, 05:35 PM
  #95
Hi. Do you have this TSB? Does anyone who can upload it? My warranty runs out at the end of tomorrow (26/03) so its a bit urgent.
Thanks. Paul
Old 03-25-2004, 05:55 PM
  #96
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
No I do not. Just tell your dealer to look it up. Be warned; I got hard starting issues after they did the work.
You have already rated this thread Rating: Thread Rating: 9 votes, 4.89 average.
Quick Reply: W203 C-Class tech bulletins
