2006 w203 c280 4matic m272 P0410
Old Feb 1, 2019 | 04:40 PM
tfwaok's Avatar
E-420
I need help with this nagging code. components all seem to check out but there is this freeze frame data.
iCarsoft
Secondary Air 1
Limit Type. Min&Max
Test Value. 0.078
Minimum Limit 0.437
Maximum Limit 1.999
Status Fail
Does anyone know the source of the voltage being measured?
Thanks,
Tommy
Old Feb 1, 2019 | 07:22 PM
tfwaok's Avatar
E-420
Originally Posted by Plutoe
Look at the secondary air system in WIS or check the various emissions systems on your car
How do l get WIS please?
Old Feb 1, 2019 | 08:51 PM
RedGray's Avatar
2005 C230K Sport Coupe
Dup post, see below. PITA forum software!
RedGray's Avatar
I don't think those are voltages. They are likely some derived value (like added air flow).
You have an Air Smog Pump on your car.
Fwiw, replacement units:
ULTRA-POWER 306018 -- $100 at RockAuto +SH
DORMAN 306018 -- ~$400
Good Luck!
Old Feb 1, 2019 | 08:57 PM
RedGray's Avatar
Buy a DAS system (~$700).
Or, buy one of the WIS softwares offered on ebay.
NOTE: You need to have a windows machine. Also, there are a few sellers. Iirc, only one seller had a decent product. It uses VMWARE.
Good Luck.
Old Feb 1, 2019 | 09:03 PM
RedGray's Avatar
Video:
Mercedes Secondary Air Pump Diagnostics and Repair P0410
iRepair Autos
Published on Feb 25, 2016
Mercedes P0410 Secondary Air Pump Diagnostics and Repair
Also, another part option, and more pictures of the Air Smog Pump unit:
Amazon Amazon
Secondary Air Injection Pump for Mercedes Benz C300 C350 E350 E550 CLS550 S550 SLK300
Price: $124.00
Old Feb 2, 2019 | 06:49 PM
tfwaok's Avatar
E-420
Smog Pump is working just fine
With the hood open, I started the car today for the first time.
Once running I immediately pull off the intake hose that goes to the pump and there was a significant suction on that hose which feeds the pump so that means relay, fuse, air pump are working. The valves on the heads are brand new as are the vacuum lines and one-way valves.
The electrical switchover component was also replaced.
That pretty much gets me down to the O2 sensors.
Good Luck!
Old Feb 2, 2019 | 07:01 PM
RedGray's Avatar
Double check the hoses/lines.
It's unlikely the (primary) O2 sensor. But, it could be the O2 sensor.
Imho, it's good to replace them after ~70K miles anyway. They "slow down" over time, and they also cause the engine to run slightly richer.
Use heat (propane/MAPP) to remove the sensor!
It could also be the cat.
But, again, it's unlikely.
Which says to me, there's a problem with the hoses/lines in the Air Smog System. They may be routed/hooked up wrong. The one-way valves may be in backwards. And, so on.
Still, my guess is that it's something in the Air Smog System.
Good Luck!
Old Feb 3, 2019 | 03:02 PM
tfwaok's Avatar
E-420
Good Luck!
The hoses have been checked so many times I can't tell you how many. I actually purchased the OEM hose components and yes, the one way valves allow vacuum flow to the intake plenum.
I have a set of BOSCH O2 sensors at the ready but really wanted to rule out everything else.
Computer is fine as the demand is there for cold starts.
l tested the air pump and it is good. Doesnt sound as loud when the hoses are on [obviously.]
CEL usually comes on after 5 or 6 drive cycles.
l hate these types of problems.
You start the engine and if the coolant temp is below a certain level after 3 sec, ECU demands the pump to turn on and triggers the switchover valve.
These things are working. I get a good temp reading so that's why the focus is now on the O2s.
I cant be the only suffering this issue.
Old Feb 3, 2019 | 05:46 PM
RedGray's Avatar
If the pump and hoses are fine, then it could likely be a marginal/semi-bad O2 sensor or Cat.
So, yes, that is a rare situation. Typically, other error codes would come up first.
If this error happened after the new heads, then again, that points to a possible air path issue.
Good Luck.
Old Feb 8, 2019 | 07:30 PM
tfwaok's Avatar
E-420
Purge Error along with Air Injection problem
Good Luck.
