My key fob stopped working all of a sudden!
You state your lock/unlock and trunk works then your infrared and led should blink. Use your phone camera, face it at the end of the key and when you press it you should see a purple led blink. You cannot see this with your naked eye and has to be viewed through a camera.
The remote function is a separate function from the key actually starting the car. The key battery can also be dead and still start the car as the computer reads the key when it is inserted and the battery is only used for the lock/unlock function.
You have 3 options -- 1 is clean the key, 2 is repair the key and 3 buy a new one. Depending on your skill level you may only be able to do option 1 and 3.
Clean your key --
Repair the key with another circuit board and solder your existing microchip onto it -- (dont worry about the key reader -- you are only wanting to follow the chip replacement and testing in your ignition)
If you go with another circuit board ensure the key type / model number you purchase is a match (i think FCC ID and another number on the plastic that holds the battery)
Most expensive and last resort option is to buy a new key from a dealer
