Transmission problems, car doesn't move
Old Jun 10, 2019 | 06:16 AM
TW203's Avatar
W203
Hello. I have a mb c240 -01 with 2.6 V6 engine. Problem is the transmisson. After stoping at a stopsign the car did not move at all. After turning it off and cool down it could work about 10 min. I changed the oil and conduktor plate and the car workd perfectly, but only for a couple of hours. Had the oil tested after that, and there was glycol in it. I took out the transmission and cleaned everything and changed the radiator. But the car still wont work.
Sometimes I can drive it obout 10min and sometimes work only in 2:nd gear or doesn't move at all.
Had it to a shop now and read codes with a star. They said that the tcu did not conect to the gearbox. They tried with another tcu but the car still did not move and no fault codes.
Also esp abs and bas light is on. Esp was on before, and abs and bas came after the transmisson started acting up.
So whar could the problem be? The tcu? Or have the glycol leak destroyd the transmisson? Or the torque converter?
Old Jun 10, 2019 | 07:29 AM
tjts1's Avatar
C320
Check the TCM for ATF contamination.
Old Jun 10, 2019 | 08:46 AM
TW203's Avatar
W203
Yes I did this, and there was no oil in it. And I belive I might have broken it when taking it apart. But it doesn't explain why the gearbox isn't working.
Old Jun 10, 2019 | 10:02 AM
TW203's Avatar
W203
I also have checked the pin plug. And it was also changed at the same time as the conductor plate.
But the car should move even if the pin plug is disconected, but only in 2:nd gear and reverse. Or so I have been told.
Old Jun 10, 2019 | 12:32 PM
tjts1's Avatar
C320
If you found grycol in the transmission the damage might already be done. The lack of communication with TCM could be that the shop is incompetent. It sounds like you're pretty handy so get your own scan tool and go from there. You might have to buy a new transmission but they're dirt cheap used. Consider using a completely separate transmission cooler so there is zero chance of future contamination.
Old Jun 10, 2019 | 02:14 PM
Pmarino's Avatar
04 E55 AMG BLK/BLK(MyDD), 06 CLK 500 (wife's) 07 ML500, 2012 C300(son's)
I have to agree, if you can rebuild it or get a rebuilt 722.6 , that would be the way to go. SDS is the way to go when trying to diagnose. As for no communication, when the shop swapped the TCU did it communicate? The pins on the trans plug are easy to bend. Did you have the original valeo radiator?
LOL my desk top is cooked, I'm on a semi broken laptop....
Old Jun 10, 2019 | 03:46 PM
TW203's Avatar
W203
Yes I also belive there is a big risk it have been damages from the glykol. The shop might be a bit incompetent yes, but they did say the got it to connect with the TCM swap. But they did not find any fault codes from the transmisson, which is also strange when the car doesn't even move.
Old Jun 10, 2019 | 03:56 PM
TW203's Avatar
W203
I have also been thinking about rebuilding the transmisson. The plate and bearing kit doesn't cost that much, but if the torque converter is broken it might cost a bit more. It' also a problem to buy a used transmisson when it is a V6 engine it need to be from a V6 engine to fit. I might get a transmisson from a E320 to fit but I don't know if it will work because the numbers are not the same. (Mine is 722696 and the E320 has 722618)
Old Jun 10, 2019 | 04:43 PM
Pmarino's Avatar
From a W203 C class M112 except the C55
Transmission 722696
18 COMPATIBLE MODEL YEARS
Mercedes-Benz C230 2002, 2003, 2004, 2005 Mercedes-Benz C240 2001, 2002, 2003, 2004, 2005 Mercedes-Benz C32 2002, 2003, 2004 Mercedes-Benz C320 2001, 2002, 2003, 2004, 2005 Mercedes-Benz C55 2005
Old Jun 11, 2019 | 03:08 AM
TW203's Avatar
W203
Transmission 722696
Thank you for this list, this will be helpful.
However, do anyone know if the gearbox numbers have to be the same or can i just swap to, for exempel the mb E modells gearbox?
Old Jun 11, 2019 | 10:35 AM
Pmarino's Avatar
Error codes 722.6
There will be differences in the sump pan as well as ratios and other internal's. I'm no expert but you can take a look at the trouble shooting guide I attached.
File Type: pdf
Old Jun 11, 2019 | 04:58 PM
TW203's Avatar
W203
Okej then I think its better to try to find one with the same numbers. But it might be more interesting to rebuild. Starting with the tcm. Then take apart the transmisson, again. If i change the conduktor plate, solenoids, change all the plates and bearing ( the hole kit) and put in the sonnax kit I should be closer to get it back on the road. If doing this, do I have to learn the transmisson or code it somehow or can i just go driving?
Old Jun 11, 2019 | 05:23 PM
Pmarino's Avatar
If you can a hold of a SDS you can look at PSI values and tell how much is left on your friction plates. Then once you get inside you can look at (for) the glycol contamination. Might be worth it to get a low miles unit and do what you are planning. If your TCU is good you should not have a problem. I highly suggest you get a SDS.
Old Jun 12, 2019 | 04:23 AM
TW203's Avatar
W203
By SDS you meen the star diagnos scaner? I was thinking about geting one, but I don't know if I should get a reader that can read other cars too.
Also they had a star scanner at the shop where I had the car but I think they may not really know how to use it.
As I wrote before I have already taken the transmisson apart and cleaned and checked everything. Problem is that it was a first timer so I did not really know how everything should look like. I did measure the friction plates, and they were okej. But they felt a bit soft and crubled a bit when toutching, so they may not do their jobb anymore.
Old Jun 12, 2019 | 08:07 AM
Pmarino's Avatar
http://www.w124performance.com/docs/..._ATSG_2004.pdf
https://lx.abodiesonline.com/Manuals/NAG1%20Manual.pdf
http://atraonline.com/gears/2006/2006-04/2006-04_04.pdf
Yes, Star Diagnostic System
Old Jun 13, 2019 | 03:33 AM
TW203's Avatar
W203
That what a lot off reading, but very helpfuel thank you.
How about the tcm. Does anyone know what the numbers meen and do they have to be the same
(A 027 545 02 32, egs51, 5wk33921) these numbers are on my tcm.
Old Jun 13, 2019 | 10:40 AM
Pmarino's Avatar
https://www.benzworld.org/forums/w21...ol-module.html
This thread may help you, particularly #4 & 7
Don't forget pages 20-22 in the ATSG manual
Finally got into my old hard drive....https://www.valvebodypros.com/assets...to-upshift.pdf
BTW I don't believe the shop that said you had no codes.
Old Jun 14, 2019 | 12:42 PM
TW203's Avatar
W203
It would not be totaly impossible that the problem is electronical. I haven't actually checked any electrical parts or checked that there is enough power to them. unfortunately I dont know **** about electronics or their parts. But again I did not know anything about transmissons either. Guess I have to learn.
I checked the codes with another tester before the star tester. And that tester said : the gear ratio is inplausible or transmisson is slipping. Or something like that. So that the star did not say anything seems strange.
