Oil in coolant, coolant in oil..
Old Sep 14, 2019 | 09:50 PM
Collin Minor's Avatar
2004 C230 Sedan
Suggests head gasket but I’m not so sure. Both the coolant reservoir and the oil cap are white-ish yellow and there’s small little bubbles in the fluid mixture on the oil cap. ATF or just coolant??? Or a mix of all 3??? Transmission started acting wonky a couple days before I noticed the cross contamination. Runs okayish, doesn’t smoke on cold start or overheat, even on the highway and in traffic it didn’t get hot I don’t think. I just bought it SUPER CHEAP with suspicions of a head problem or something, idle was poor, although drove pretty decent. Checked the fluids and they looked dirty but okay. Now this, I’m confused. I’ve seen plenty of head problems in my short time on this earth. None of them quite like this. For a head leak of the size it’d need to cause this much contamination in such a short time if I’m not mistaken it should smoke or overheat at the least. It does neither. I’m not freaking out over a possibly having to pull the head, but I’ve read threads on an oil cooler leak that could possibly cause this. Just wanted to see what some Vets have to contribute on this before it gets torn down. TIA! - Collin
EDIT: Poor idle and performance was mostly caused by a vacuum leak which was fixed within a couple of days. Now it’s only half as bad. Which points me more towards a head gasket as well. Thanks again!
Old Sep 14, 2019 | 10:46 PM
chassis's Avatar
2017 GLE350 4MATIC
Get some data. You already have visual data on the reservoir caps, and the wonky transmission performance.
Does the exhaust smell like burning oil, or have a sweet smell?
Do a compression test, and a leak down test.
Do a coolant pressure decay test.
Drain and replace the coolant, engine oil and transmission fluid. Note the color, smell and consistency of each one.
Pull the spark plugs and look at them, note differences in appearance.
Look into the cylinder through the spark plug hole with a bright light, to see if the tops of the pistons are "washed", or shiny from coolant.
Old Sep 15, 2019 | 12:11 AM
2004 C230 Sedan
It doesn’t have a sweet smell from exhaust nor does it smell like oil. All I smell is a strong odor of gasoline but past that nothing else. I wish I had all the tools available to me to do such. At the moment I do not. I’m pretty sure you need an E-socket to get the coils out anyways and I do not have a set. Will be picking one up Friday. But for now, any guesses? It’s a C230K. Around 190,000 miles. Bought it to see if I could make something cool out of it. Don’t see many of these on tracks and at meets and such. Figured I’d try my hand.
Old Sep 15, 2019 | 05:44 AM
2004 C230 Sedan
I figured I’d do what I can today and see if I could get a little more info. I took the coils and plugs out tonight. What I found was horrific. The #1 and #2 coils were wet with oil and coolant. #1 was almost a 1/4 of just water above the plug and the rest oil. Plug tips don’t look wet at all and all my cylinders have adequate carbon build up for 189,000 miles. My question is what would cause that much oil and especially water to pool up above the spark plugs but not cause any smoke? Cylinder #1 had to be my dead cylinder because of the condition of the plug and the boot having all that oil and water in it. No white or “clean” plugs. So it’s not burning any coolant. I’m stumped! Thanks for you help! I really greatly appreciate it!
Old Sep 15, 2019 | 02:35 PM
RedGray's Avatar
2005 C230K Sport Coupe
If you're in the USA, at least put what general part of the Country that you are in.
Fwiw, the M271 American-version is unique.
Check the oil-cooler for a leak. Search.
Do a dry and wet compression test.
As for the oil/coolant in the spark plug holes, likely some incompetent person yanked the valve cover, and put it back on wrong, or re-used a bad gasket.
Your timing chain is a massive POS! It should be REPLACED every ~70K miles. The M271 is an interference engine.
You don't have to change the timing chain. You also don't have to ever ever change the oil.
What type of "track" - NASCAR, Circle, Auto-x, 1/4 mile?
For a GOOD AMOUNT OF MONEY (~$5K+++), there's ~~~20-30 real life HP that can be gained.
Is that "worth it"? Imho, that's a depends on the person and the reasons.
Imho, everything (HP wise) else is BS snake oil - buy an ebay battery-powered supercharger, put on a 12-foot wing on the back, put neon lights under the car, and you're well on your way.
There are some stiffer sway bars. Wider tires likely won't fit. Get/use REAL (DOT-legal) race tires for the track.
Good Luck!
Old Sep 15, 2019 | 02:43 PM
RedGray's Avatar
Btw, as for NASCAR-type of tracks, a person here posted his C230K on a real track (?Talladega?). His normal track car was down for the week. He also has extensive track time and knowledge.
Imho, a C230K, properly done, can be a "respectable" track car. The Vettes, Stangs, and BMWs are still going to blow by. I said respectable, not top competitor worthy.
Oh yea, you should also upgrade the brakes. Again, search.
Good luck.
Old Sep 15, 2019 | 03:35 PM
chassis's Avatar
2017 GLE350 4MATIC
Good job on collecting more information. You bought the car cheap, you are now getting an idea why it was so cheap. If it were mine, would go through the engine thoroughly, using the diagnostic tests listed above. Depending on your goals for the vehicle, there are options. Repair or replace the engine are the two basic avenues to consider.
Old Sep 16, 2019 | 01:51 AM
RedGray's Avatar
Originally Posted by RedGray
As for the oil/coolant, likely, some incompetent person yanked the valve cover, and put it back on wrong, or re-used a bad gasket.
I meant to say, 'As for the oil/coolant in the spark plug holes,'
Old Sep 17, 2019 | 11:24 PM
2004 C230 Sedan
Well yeah in a while ill go through it. I just don’t have all the time right now. I’m maintain commercial properties, I’m on call 24/7. I plan on tearing it down either Wednesday night or Thursday night. Im not in dire need of the vehicle ATM. But I appreciate the help! I just got confused because I read some things online and got confused. It doesn’t show any signs of blown head but that and I wanted to be sure. Still tearing it down. I was more worried of cracked head, I am not familiar with these vehicles and their shortcomings. I got the opportunity to buy it super cheap and figured I’d try my hand at something. Either way it’ll be back on the road soon. As to the track, I have more of a different vision than you might imagine. Not NASCAR. I’d really just love a fun car to drive in the country where I live. Beats driving a pickup everywhere you go. If I can do it for under $1500 bucks, great. If that soon turns into $3000, I’m fine with that. To know it’s solid and can get me across these mountains and put a smile on my face while doing it I’ll pay that gladly.
Old Sep 18, 2019 | 07:38 PM
2004 C230 Sedan
Good Luck!
So pull the oil cooler and inspect seals? Would a failure in the seals cause contamination both ways or would that be an internal failure? I can’t find much literature on oil cooler failures.
Old Sep 18, 2019 | 11:22 PM
RedGray's Avatar
For a MB, search by the engine name (M271) and/or the chassis name (W203).
Google:
M271 oil cooler replacement.
As for why it leaks, it's a cheap/poor design.
Here's an article about replacing the gasket on another engine. Note that it's a PITA on an M271.
https://www.pelicanparts.com/techart...eplacement.htm
The following picture should give you an idea why the oil and coolant may mix:
Note that, all coolant is very corrosive to all bearings and bearing surfaces. The longer that there is coolant in the oil, the more damage that is done to the bearings and the bearing surfaces.
Knowing the needed maintenance areas, and being able to do the work oneself, can make an older MB a good purchase.
Otherwise, imho, the purchase is a waste of money.
Good Luck.
Old Sep 27, 2019 | 02:27 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Ah OK, so sounds like 2 issues,
1. this oil cooler (assuming you have M271)
2. Valve cover gasket and orings around the spark plug holes (go on the vavle cover)
thats how oil (and since coolant is getting in the oil)
gets into the area where the coil is.
Old Sep 27, 2019 | 05:30 PM
lululu's Avatar
94 e320s
i had a friends 271 4 cylinder with oil in coolant , looked like milk shake , was the oil cooler small box looking one, and tested it by closing the oil port and installing in a bucket of water and putting air into the oil section , bubbles leaked
