Code out ABS?
Old Sep 25, 2019 | 06:16 PM
steaksausage's Avatar
c55
Code out ABS?
Hello everyone, first post here so I’d like to introduce myself...
I own a 2005 C55 that is quickly becoming a purpose built drift car. Without going into extreme detail, I’ve fitted Ceika coil overs, f1 fab front and rear camber/toe arms, Kmac front caster arm bushings, built custom end links to prevent them from snapping during full lock, installed hydro ebrake welded the diff, and finally, sent the ECM to vivid racing for a tune. All the while, I left the car in dyno mode to prevent the abs from getting upset. I suppose I should also mention, I have a Chrysler crossfire 6 speed swap waiting to be installed after this drift season concludes (next weekend)
fast forward to today, when my (improper) NRG wheel hub came in and I installed it. While the fitment was poor, it did go on... however, now the car is upset that it’s not seeing the steering angle sensor and it’s stuck in sport mode.
Which has led me to here. I have almost unlimited diagnostic software at my disposal (We have an active copy of DAS) however I am not very familiar with it, being that I am a VW tech at heart.
Is there a way to effectively code out, or tell the car to stop looking for, the abs module? Seeing that I’ve fitted an aftermarket wheel, I’ve also lost the ability to put it back in dyno mode should I disconnect the battery for some reason, so it’s pretty much to the point where it’s essential to remove the abs. Simply unplugging the module prevents the electronic selector module from allowing the vehicle to come out of park, so that’s kinda a non option at this point.
looking forward to hearing from fellow MB enthusiasts
Old Sep 27, 2019 | 02:13 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
There probably is a way to code that stuff out, with an SDS.
So many options in there.
I thought I posted this yesterday, but just FYI was reading codes with my iCarsoft unit the other day, and
just the act of having it connected put the car into Dyno mode.
Not sure if it happened immediately or when I was reading ESP code or transmission,
but it wouldn't got off till it was disconnected..
Old Sep 29, 2019 | 02:59 PM
Russell Ormerod's Avatar
not a merc
That's what happens when you connect cheap diagnostic tools to a car. Commands are sent that shouldn't be sent. Coding gets changed without you knowing. About the ABS coding, you need to look in development data in the engine ecu ME2.8 is what you have I think. But I very much doubt you can code ABS out of it because there is not a Mercedes without ABS so there is no option to remove it.
Old Sep 29, 2019 | 08:06 PM
BF_JC230's Avatar
2005 w203 C230
Mmm...
I haven’t seen an option to code out ABS fully...
I’ve made a few changes to my module to try and bring on Distronic...
Ah CODING/or setting the correct tab...
The BANE of my Distronic project.
Good luck! Next time I’m plugged in I’ll take a look when I quadruple check my ABS/ESP settings...or if I play around in simulator...
Old Sep 29, 2019 | 08:10 PM
BF_JC230's Avatar
2005 w203 C230
Russell...
Doesn’t look like there’s a Mercedes with Distronic that’s not a NAG (New Automatic Gearbox)...and I have (and love) a 6 speed manual...so it turns on well at key hot - and faults out with engine on.😪
Old Sep 30, 2019 | 02:09 PM
not a merc
Try the other coding function explicit coding, where you can code item for item.
Old Sep 30, 2019 | 05:36 PM
BF_JC230's Avatar
2005 w203 C230
Can’t “find” Explizit for my m271 SIM4 LE...
I did set it to “ART”...still nada.
Old Oct 1, 2019 | 12:32 AM
not a merc
Use vediamo
Old Jun 15, 2021 | 03:12 PM
iMikeG's Avatar
2002 C230K 6sp
BUMP HAS ANYONE FOUND THE CODING FOR THIS FOR THE ABS UNIT?
Old Jun 15, 2021 | 09:23 PM
BF_JC230's Avatar
2005 w203 C230
To “code out” ABS or add Distronic on a manual transmission car?
I am about to start back up on trying to get DTR to work in my 716 transmission m271 powered w203…
Old Jul 8, 2024 | 09:15 AM
E34's Avatar
E34
E34 with m113k
Me2.8.1
I have the same problem. I have an e34 with m113k running only me2.8.1 and 6 speed manual. Car is stuck in Limp mode. Any luck you guys?
QUOTE=BF_JC230;8357794]To “code out” ABS or add Distronic on a manual transmission car?
I am about to start back up on trying to get DTR to work in my 716 transmission m271 powered w203…[/QUOTE]
