Hi guys.
Please I've got a new problem with my w203.
The water in the water tank usually stays for days before coming short and then I refill.
But recently I get to refill every day as it goes down significantly. It became worse today as I had to stop and refill twice on the road after the morning refill.
Please I need help
What should I do
Please I need help
What should I do
Quote:
What should I do
Take it to a mechanic.Originally Posted by Zee1000
Please I need helpWhat should I do
Quote:
I would, on a peaceful note, tell you to be smarter with your response.Originally Posted by tjts1
If you didnt think that I would definitely take it to the mechanic before coming here to state the obvious, then you're slow.
Please try to think before throwing responses.
Please anyone with an answer that would give me an insight to what might be causing such should reply me.
Thank you.
Thank you.
WTF is your problem?Originally Posted by Zee1000
I would, on a peaceful note, tell you to be smarter with your response.If you didnt think that I would definitely take it to the mechanic before coming here to state the obvious, then you're slow.
Nobody on this or any other forum is going to accurately diagnose your coolant loss without looking at the car. You didn't even include basic information like model year, engine type or service history. So if you're that lazy and incompetent please do yourself a favor and TAKE IT TO A MECHANIC.
Quote:
Nobody on the internet is going to accurately diagnose your coolant loss without looking at the car. You didn't even include basic information like model year, engine type or service history. So if you're that lazy and incompetent please do yourself a favor and TAKE IT TO A MECHANIC.
Thank you man. I appreciate you.Originally Posted by tjts1
WTF is your problem?Nobody on the internet is going to accurately diagnose your coolant loss without looking at the car. You didn't even include basic information like model year, engine type or service history. So if you're that lazy and incompetent please do yourself a favor and TAKE IT TO A MECHANIC.
God bless.
And I hope you get better
I don't think this platform is for fighting or exchange of violence.
Someone by page name rudeney actually helped me with my last post.
Helped me through a week long stress with my car.
In appreciation I won't get into a word fight with you.
Let love lead your heart man.
You obviously have a leak. Look for dried coolant then go from there. But yes we need more information if you want model specific advice.
If you're losing that much coolant in a day your engine bay must be soaked.
Thanks man.Originally Posted by slammer111
You obviously have a leak. Look for dried coolant then go from there. But yes we need more information if you want model specific advice.If you're losing that much coolant in a day your engine bay must be soaked.
I'm going to the mechanic first thing tomorrow morning.
Just want to have an idea what could be wrong
And what I would possibly face in terms of cost
That's why I brought it to the house.
A leak shouldn't be a huge problem.
But the water in the engine bay, doesn't sound good
ExploreSuper Member
Please update your user profile.
Put in the Year, Model, say if it's Diesel, and at least your Country(some models vary by country).
Depending on the year and model, there's a decent chance that the car is junk.
It sounds like you have a bad radiator. Some models and years had poorly designed radiators that would also leak into the automatic transmission cooler lines. That could, and often would, run the transmission.
Cost and the amount of work to replace the radiator depends year and model. And, of course the local cost of parts and labor.
Also, if the radiator is leaking that bad, you should see water on the ground.
Good Luck.
Good Luck.
Good Luck.
Mercedes Benz c class sedan w203 2003. Compressor. Originally Posted by RedGray
Please update your user profile.Put in the Year, Model, say if it's Diesel, and at least your Country(some models vary by country).
Good Luck.
Quote:
W203 is the platform, not the car model. The car model should be on the car, often on/near the trunk.Originally Posted by Zee1000
The W203 car models are:
If you mean Kompressor, not Compressor, then it may be a C230.
Kompressor is the German spelling of Compressor.
If you have a 2003 C230K, then, I think, that still had the poorly designed radiator.
When you added water before, if you saw that the water/anti-freeze had "foam", that's not a good sign.
You'll have to see what the mechanic says.
Of course, since the transmission is still working, you could get a transmission fluid flush, and see how long the transmission would last.
And, of course, you could always get a rebuilt or used transmission.
Again, please add the info you your user profile. That is the first thing many of use look for.
There are many of W203 models, I know only a very few.
Good Luck
Good Luck
Mine is c230. 2003.Originally Posted by RedGray
W203 is the platform, not the car model. The car model should be on the car, often on/near the trunk.The W203 car models are:
Good Luck
There is no transmission fluid or foam in the water tank.
It is clear.
Just that the water keeps coming short for such a short driving distance.
Quote:
Sup tjts1Originally Posted by tjts1
So take it to a mechanic.
How u doing
Took it to the mechanic today.
Turns out the upper hose was torn.
For torn because it was touching the engine belt pulley
Its fixed now
Thank you man.
Blessings
Its fixed now
I'm glad that you got it fixed, and it wasn't anything major.Originally Posted by Zee1000
Took it to the mechanic today.Turns out the upper hose was torn.
Its fixed now
Thanks for the update.
Awesome, I'm glad you got it fixed. That's the type of thing the Forum would have never been able to diagnose.
